Page 114 of 295 FirstFirst ... 1464104109110111112113114115116117118119124164214 ... LastLast
Results 1,696 to 1,710 of 4422
Thread: VVDI PROG
  1. #1696
    bursuc's Avatar
    Oct 2011
    inside MCU
    I attach some pictures. Regards
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
  2. #1697
    bursuc's Avatar
    Oct 2011
    inside MCU
    Quote Originally Posted by bursuc View Post
    Now i desolder the yellow battery and i always have red light. I can see FW verzion and update it but red light is constantly on...
    Any advice on this?
    Thanks in advantage!
  3. #1698
    kevfield's Avatar
    uk
    yes send back to who ever you buy from because firmware is damaged because you disconnect batt...
    Thanks Kev
  4. The Following User Says Thank You to kevfield For This Useful Post:
    bursuc (22nd November, 2017)
  5. #1699
    Mar 2017
    Colombia
    Quote Originally Posted by Samic View Post
    which option you tested and please post here the unit clearly PCB photos.
    Photo of ecu... 3132. Siemens...
    20171117_134746.jpg]
    WINNER THE LOSER
  6. The Following User Says Thank You to automotrizVIP For This Useful Post:
    Samic (22nd November, 2017)
  7. #1700
    Apr 2015
    Any advice on this?
    friend, your device must send back for repair, will check the caused reason and solve the problem.
    one more thing, without technical permission, any problem don't working on device PCB directly,
    otherwise factory will refuse to repair. PM me your device SN, i will explain to factory.
  8. #1701
    EU
    Today i got new VVDI EWS3 ADAPTER but is not working to read test unit (EWS3 0D46J).
    tryed vvdi prog version 4.6.4 and 4.6.3
    X-Prog read same unit with no problem.
    If my Post is/was helping you... Please press THANX or give REPUTATION
    THANX
    I am sorry for my bad english
  9. #1702
    Mar 2017
    Colombia
    [2017-11-22 15:28:02] : Select <Read ID>
    [2017-11-22 15:28:02] : Check Device...
    [2017-11-22 15:28:04] : 12V Power Adaptor unconnected
    [2017-11-22 15:28:04] : Initialization device...
    [2017-11-22 15:28:04] : Initialization success!
    [2017-11-22 15:28:05] : Initialization chip...
    [2017-11-22 15:28:06] : Start communication...
    [2017-11-22 15:28:06] : End communication...
    [2017-11-22 15:28:06] : Operation success
    [2017-11-22 15:28:06] : ID:01
    read ok verify ok .....
    USE
    from read ecu renault EMS 3132 Siemens pin out ok .....
    indicates the pins with arrows......
    RED---------VCC
    black-------GND
    COFFE------TXDO
    ORANGE---RXDO
    BLUE-------POL.4
    GREEN-----POL.5 PIN 29
    YELLOW----RESET
    WINNER THE LOSER
  10. The Following 3 Users Say Thank You to automotrizVIP For This Useful Post:
    Faraday (22nd November, 2017), koyot (22nd November, 2017), Samic (24th November, 2017)
  11. #1703
    Apr 2009
    RS, BRASIL
    Samic, i made the modifications like in soft pict
    friend, please check your device adapter whether inside wires connection good as sample photo.
    if check same but still cannot read let me know.
    Attachment 486090 Attachment 486091
  12. The Following User Says Thank You to valdirld For This Useful Post:
    mexjack (22nd November, 2017)
  13. #1704
    Jun 2014
    Quote Originally Posted by derdud View Post
    I tried VVDI EWS3 adapter.Worked fine for me.Can't remember which software version I used.
  14. #1705
    Oct 2016
    I bought vvdi prog especially for unlock kia/hyundai smart keys, but i can't buy renew files somewhere, how can i get them? I'm a bit disappointed, I can not use it for what I bought. Samic maybe you can help me?
  15. #1706
    Jan 2016
    Quote Originally Posted by giorgioma View Post
    May be a vvdi key tool is better for you.
    Envoyé de mon MI PAD 3 en utilisant Tapatalk
  16. #1707
    Jan 2013
    some file for hyundai key pass in pm
  17. The Following User Says Thank You to fytfh For This Useful Post:
    giorgioma (23rd November, 2017)
  18. #1708
    Oct 2016
    Don't forget to send me pass please, thank you
  19. #1709
    ibratex's Avatar
    Jul 2015
    angola
    Mate ... in vvdi prog the pcf adpter will read and reset sec but you cant write ..i tried a lot 1 month every day ...samic said dosent need verify but its the same i write eerom vvdi and eeprom the key is always locked i wass working on nissan smartkey 4 buttons ..... even on adapter dosent read at all only onboard
    Samic we need solution pleease
    Sent from my SM-G935F using Tapatalk
  20. #1710
    Oct 2016
    I unlocked BMW F series smart key and Hyundai Sonata key HMFNA04 i have not exactly this renew file but i wrote there HMFFEU04 file and tango detected it as factory unlocked key. I have not tested on car it yet. I hope it will work. You are right last lines doesn't eraseing and writing but anyway tango detects as new key.
  21. The Following User Says Thank You to giorgioma For This Useful Post:
    taxo1965 (1st February, 2018)
