Page 130 of 295 FirstFirst ... 3080120125126127128129130131132133134135140180230 ... LastLast
Results 1,936 to 1,950 of 4422
Thread: VVDI PROG
  1. #1936
    Mar 2017
    Colombia
    reporting; read eeprom AT25C320 does not respond, USE ST, ATMEL.
    I passed it on different adapters and soldered it on tracks, without answers from the program, reading st95320 is good, but at25c320 is not possible...........................
    finish work with upa,
    WINNER THE LOSER
  2. #1937
    Apr 2015
    Quote Originally Posted by EMCE159 View Post
    Yes before and after, nothing changed in eprom. I think that vvdi reads something from processor to decrypt eprom. All this situation is not a big problem I just fit another one, I have ecus and working key so all needed data. But for the future it would be good if this was corrected, reading unknown version shouldn't corrupt kessy.
    friend, if the 93c86 data keep same before and after, it means the dump should be correct.
    about your problem mostly caused reason should be on hardware, pls check again.
  3. #1938
    Apr 2015
    Quote Originally Posted by eliaselias View Post
    bmw cas3 read eeprom ok .... but flash could not read ... i get error message to check my connection or to check mcu type.... cas still alive thanks....
    atmel eeprom 93c76 read bad data
    mate, pls send me the log file or read error screenshot.
    pls just connect device to PC with USB cable(not run software), then measure the eeprom socket PINS voltage, let me know the result.
  4. #1939
    Apr 2015
    Quote Originally Posted by offsystem View Post
    St 95320 ee delete and rewrite not possible
    About ST95320 beside EEPROM, there is a 'Lock byte'in STATUS. when you want to rewrite data, this Lcok byte must keep '00'.
  5. #1940
    Apr 2015
    Quote Originally Posted by automotrizVIP View Post
    try to this option with 4.8V, this old chip the working voltage a little higher.
  6. The Following 2 Users Say Thank You to Samic For This Useful Post:
    daxxer (18th January, 2018), habbyb (18th January, 2018)
  7. #1941
    Jan 2016
    So VVDI PROG to decrypt data needs only eeprom or it reads also part of MCU from this board ??
    Quote Originally Posted by Samic View Post
  8. #1942
    Dump was correct. It was spare key job, EE read onboard then soldered your wires. Impossible to damage. I think NEC got corrupted.
  9. #1943
    I got mine vvdi prog,
    work good but need external power,
    I use too original xprog-m and no need external power - that is main difference
    So if someone have trouble with working VVDI Prog first please check external power to programmer
  10. #1944
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by gif_kuba View Post
    in what case you need use external power for VVDI Prog ??
    many thanks to friend kevfield
  11. #1945
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Most of the chips i read without external power but some MCU's require external power!
  12. #1946
    Oct 2015
    Why this things aren't automatic? I mean, if this eeprom needs this voltage, when you choose whatever chip, voltage and other settings should set automatic.
  13. #1947
    igorr's Avatar
    Aug 2010
    CAS 3+ wont read mcu id c410 ok 0L15Y but cant crack mcu mesage check connecion
    35080 cant erase with adapter
    job done with 50$ R270
  14. The Following User Says Thank You to igorr For This Useful Post:
    PierreTheron (19th January, 2018)
  15. #1948
    Oct 2016
    Scotland
    Quote Originally Posted by igorr View Post
    CAS 3+ wont read mcu id c410 ok 0L15Y but cant crack mcu mesage check connection
    I just did one of these today with no problems, did you double check all your connections were ok?
    I've had this message in the past, and turned out one of the wires wasn't making a very good connection. Re-soldered it and was fine.
    When you click the "Read ID" button in the top right corner, does it actually come back with C410? The time i had a bad connection every time i clicked the 'Read ID' button it would come back a different random ID
  16. #1949
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Never had problems with CAS3 units. Check your connections mate.
  17. #1950
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    all mainly only about bad connecting, bad soldering or not cleaned legs - when use socket....etc...
