Page 134 of 295 FirstFirst ... 3484124129130131132133134135136137138139144184234 ... LastLast
Results 1,996 to 2,010 of 4422
Thread: VVDI PROG
  1. #1996
    Oct 2017
    Quote Originally Posted by inaro View Post
    the eeprom is 35080 6
    vvdi read it as 35080v6
    vvdi cant read it as 35080 6
    vvdi cant errase it at all
    the software indeed has problem.we'll fix it soon.please for temperary solution:solder chip on the board,and use the 35080v6 option to read and erase,it works.thank you,mate.
  2. The Following User Says Thank You to Xhorsesupport For This Useful Post:
    nemena (31st January, 2018)
  3. #1997
    Thanks for the feedback. So this problem is not adapter related?
  4. #1998
    Feb 2013
    Can there be a scheme of adapters?Can adapters be adapted from Xprog? Thanks.
  5. #1999
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Probably not! That would be unlogical!!!
    Quote Originally Posted by taxo1965 View Post
  6. The Following User Says Thank You to sniegavirs For This Useful Post:
    taxo1965 (1st February, 2018)
  7. #2000
    Jan 2012
    Quote Originally Posted by solitaire View Post
    some D76Fxxx can read as D70Fxx
    eg. D76F0117 > D70F3379
    just campare flash size
    D76F0115GM
    , used on renault fluence bcm - try read as UPD70F3385
    D76F0018GJ, used on some peugeot bsi (V850) - try read as UPD70F3379
    What i should select for D76F0198GD , when i can't find any document to understand flash/memory size etc ?
    Best Regards
  8. #2001
    Jul 2008
    romania
    ford monde68hc912d60 dash not woking.....bkgd reset vcc and gnd.....not finding frequency....i have tryed all manual and auto.cfg.....nothing
  9. #2002
    Mar 2017
    Colombia
    68hc912d60 in some cases this happens and you must lift some bolts.
    in upa-s this happens.
    you must check first if your connection is correct.
    WINNER THE LOSER
  10. #2003
    Jul 2008
    romania
    Quote Originally Posted by automotrizVIP View Post
    xprog.....do it withot lift anything
  11. #2004
    Moderator
    PremierD's Avatar
    Jun 2009
    Then use xprog mate ...:
  12. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    PierreTheron (25th May, 2021), ruffles1986 (3rd February, 2018)
  13. #2005
    Jul 2008
    romania
    Quote Originally Posted by PremierD View Post
    why mate ? if is stated in that menu ...if it was the only tool ..
  14. #2006
    skens's Avatar
    Zagreb,Croatia
    hi
    Problems with 908hp12!
    I'm trying to connect to the 908LJ12, the JCB table!
    did anyone connect with 908LJ12?
    i use cable v3 !!
    please instructions
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  15. #2007
    Quote Originally Posted by Xhorsesupport View Post
    Software checked,no problem.Please post a clear picture of your soldering chip on board,let's help have a look.
    After having problem with this chip, all other i tested failed..
    I found the problem.. one of the pins on the board was all bend and didnt make connection haha
    That was a bad expirence. All works fine now
  16. #2008
    Jul 2008
    romania
    95040 read fine cant write ...lower the voltage to 4.5v and write fine
  17. #2009
    Mar 2017
    i received the new adaptor for m35080 but not working
    when read the chip all show 00 00 00
    tried ti solder on the board also the same result
    now i dont know what is the problem
    software bugs or hardware?
  18. #2010
