Page 136 of 295 FirstFirst ... 3686126131132133134135136137138139140141146186236 ... LastLast
Results 2,026 to 2,040 of 4422
Thread: VVDI PROG
  1. #2026
    Feb 2013
    Yesterday I received a VVDI Prog.
    Tested: Many thanks to the developers.
    906 sprinter 2007 9s12 Read/Write eeprom-flash ok
    immo Vito 908 0j66d Read/Write ok
    w211 2005 9s12 Read/Write eeprom-flash ok
    S9S08DZ60 (2M74K) Immo IK BYD 2011
    sorry protection can not get around.I hope the developers will solve this problem
    Eraze+Unlock works checked, my block for spare parts
    Best Regards
  2. #2027
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by obeids View Post
    Which is the best programmer for CAS4?
    The VVDI gave me grief and it seems to have killed the CAS.
    VVDI Prog is great for CAS4! It is not tools fault that you obeids were not careful enough doing your job. And with correct PFlash and DFlash your Cas4 could be working again but that depends only on you yourself. I have done around 11 CAS4 at the moment and never had any problems!
  3. The Following 8 Users Say Thank You to sniegavirs For This Useful Post:
    AndyCZ (19th February, 2018), daxxer (16th February, 2018), Hayssam1 (18th May, 2018), laki23 (18th February, 2018), lalaina74 (16th February, 2018), Maartinj (15th February, 2018), p1et (15th February, 2018), vsanyi (15th February, 2018)
  4. #2028
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by sniegavirs View Post
    100% agree
  5. The Following User Says Thank You to Maartinj For This Useful Post:
  6. #2029
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Had a chance to play with BMW X4 F26 Airbag unit ACSM4 due to internal pcb element problem. Did not find any information on how to properly read this unit since it is glued together as seen in pictures so i cutted the case carefully and now if needed i will only cut out a little window at the corner(shown in picture) to read/write the unit. Only those 4 pads needed 1. BKGD 2.VCC 3.Reset 4.GND Maybe Xhorse can take this information to VVDI Prog software.
    Only memory on PCB is MCU 9S12XET512 (UNSECURED)
    These Airbag units also installed on BMW F25 X3 and F10/F11 5series
  7. The Following 12 Users Say Thank You to sniegavirs For This Useful Post:
    andresfn18 (19th February, 2018), aone222 (16th February, 2018), BradyAus (20th October, 2018), brane0001 (4th January, 2020), bry0sb (27th February, 2018), castin (25th April, 2023), danielif (20th February, 2018), eugen8 (17th March, 2019), fytfh (16th February, 2018), Perryking (16th February, 2018), u.s (9th March, 2018), vasa (16th February, 2018)
  8. #2030
    Batumeli's Avatar
    Batumi. Georgia
    Hello!
    my programmer vvdi prog stopped reading the processor 9S12 secured.
    Not in MB locks and not in CAS. Maybe someone's got a problem with such a problem? In the technical support wrote not who did not answer!
  9. #2031
    16-26.02. is Chinese New year. You will not get any support during this time
  10. #2032
    Feb 2016
    reposted with proper quotes
    +thanks if I helped you!
  11. #2033
    Feb 2016
    send a pm if you need dump, i have one reading from a good unit and you can test if internal fault goes away
  12. The Following User Says Thank You to tibibond For This Useful Post:
    sniegavirs (16th February, 2018)
  13. #2034
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by tibibond View Post
    Thanks but no need. By internal i meant that something on the PCB is damaged after the crash of the car! Now it doesn't recognize new airbag replacement. Tested the wires and all is ok. Even connected ~3ohm resistor to test if it is airbag fault but still nothing. But when i shortcircuit those 2 wires it recognizes that the resistance is too low so it means something on the PCB is blown out due to activation of airbag while crash happaned. I will be changing the ACSM unit.
  14. #2035
    Jul 2008
    romania
    Default fiat immo not working
    od66j motorola hc908 not working in circuit
  15. #2036
    Oct 2017
    Was able to read eeprom & flash of W211 with VVDI Prog, but now EIS dead, no power, immo coil tested no light. Rewrote new flash, still dead. Used doner EIS before connecting to VVDI Prog, tested immo light would come on, now after read and write doner EIS not lighting up, dead. What's the deal?
    Sent from my ASUS_Z00AD using Tapatalk
  16. #2037
    Oct 2017
    Quote Originally Posted by djjazzer View Post
    Maybe this board is not supported by VVDI Prog? Had to use Smok diagram for reading. EIS is 2115452308
  17. #2038
    MC9S12XS128_UNSECURED - dont work without external power !
  18. #2039
    Aug 2015
    Quote Originally Posted by gif_kuba View Post
    Only this mask XS ?
    Gesendet von meinem SM-G935F mit Tapatalk
  19. #2040
    Quote Originally Posted by offsystem View Post
    Only this mask XS ?
    i try yesterday this mask and work only with external power to programmer,
    with xprog-m original work without external power
