Page 142 of 295 FirstFirst ... 4292132137138139140141142143144145146147152192242 ... LastLast
Results 2,116 to 2,130 of 4422
Thread: VVDI PROG
  1. #2116
    Apr 2015
    Quote Originally Posted by obeids View Post
    Connected this again to another ECU with St10F269. It identifies the CHIP ID and I can press WRITE and it goes all to the way to 100% and says Success.
    WHen I press read then it give READ ERROR. WHat is the problem? Is it something faulty with VVDI prog or what? If my connections were not right then why does it identify and write but cannot read? And I tried 2 different boards so means ever wire resoldered.
    Hi friend, very strange as you said.not sure the caused reasom, could you tell me the exactly ECU type module(better with photo), we will get one same unit and test again.
  2. The Following User Says Thank You to Samic For This Useful Post:
    daxxer (22nd March, 2018)
  3. #2117
    Apr 2015
    Quote Originally Posted by Cardiag.ru View Post
    SPC560P34 not work.
    SPC560P34 currently not support by VVDI PROG, we are still working on this chip.
  4. The Following 2 Users Say Thank You to Samic For This Useful Post:
    daxxer (22nd March, 2018), taxo1965 (22nd March, 2018)
  5. #2118
    Apr 2015
    Quote Originally Posted by pierre renault View Post
    Should Samic be upset with people?
    friend, not like this just because currently overseas technical support only me, everyday very busy, even i cancelled my trip.
    from next week i will training new comers as technical support for overseas customer. any problem you can post here, when im available will check.
    Samic always member of DK forum.
  6. The Following 7 Users Say Thank You to Samic For This Useful Post:
    BradyAus (20th October, 2018), daxxer (22nd March, 2018), laki23 (22nd March, 2018), magdyman (25th March, 2018), mickye_dj (22nd March, 2018), sniegavirs (22nd March, 2018), taxo1965 (22nd March, 2018)
  7. #2119
    Apr 2015
    Quote Originally Posted by Hammon View Post
    Hi dude'S!
    I would like install for win10 64 bit ver. I try 3 versions a vvdi prog . Not work.All times said the system this is a win 8 applications. Have you any idea how its made?
    Thank you!
    mate, try to change setting on windows defender manually, last month i contacted with Microsoft to improve this for all users, but seems they still haven't changed anything.
    if still with problem, let me teamview check with you.
  8. The Following 2 Users Say Thank You to Samic For This Useful Post:
  9. #2120
    Apr 2015
    Quote Originally Posted by drpeter View Post
    I tried to read/write a new VW UP dash with 70F3525 onboard today with VVDI, VVDI reads ok, but write error after 38%, even with a 1kOhm resistor connected. What is going on? See schematic.
    thanks for your feedback, we will get this chip and testing again.
  10. The Following User Says Thank You to Samic For This Useful Post:
  11. #2121
    Apr 2015
    Quote Originally Posted by drugowaz View Post
    Please give tip
    Porsche bcm 2016
    When mcu os crypt need to reset security and after write set it again FF
    When mcu not crypt message is FE and after write need go to set security and put in FE or just write and leave like this.
    Ive done only crypt . Saw video where read porsche not cryp mcu ..512vag. And there not set securitu after write.
    friend, all Porsche the security byte is 7D, For BMW CAS4 the security byte is FF.
  12. The Following 4 Users Say Thank You to Samic For This Useful Post:
    BradyAus (20th October, 2018), daxxer (22nd March, 2018), mickye_dj (22nd March, 2018), taxo1965 (22nd March, 2018)
  13. #2122
    Mar 2017
    Colombia
    hello friend @samic any chance to add this type of reference with proper reading
    Ecm Renault.....
    Renault
    Valeo V40/V42 (SH7058/1024KB)
    Sagem 3000 (SH7055/512KB)
    EMS3110 (TC1766/1504KB)
    Logan, Sandero, Fluence, Megane, Almera EMS3120 (TC1738/2048KB)
    Duster, X-Ray EMS3125 (TC1782/2560KB)
    Clio 4 1.6T EMS3150 (TC1767/2048KB)
    Reading, writing, checksum correction.
    Bmw eeprom soic 8
    Eeprom 160DOWT ....
    Thank you
    WINNER THE LOSER
  14. #2123
    Apr 2015
    Quote Originally Posted by automotrizVIP View Post
    Ecm Renault.....
    Renault
    Bmw eeprom soic 8
    Eeprom 160DOWT ....
    Thank you
    we have to find those unit for check first, if you can provide us we can add fast.
    for BMW 160DOWT its difficult to support.
  15. The Following User Says Thank You to Samic For This Useful Post:
  16. #2124
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Quote Originally Posted by Samic View Post
    so if i get message chip not crypt no need set security in end?
    Insaid FF like exaple from cas4
  17. #2125
    Apr 2015
    For Porsche if the security byte is Not 7D or without security byte after install BCM back may caused not working.
    for BMW security byte even wrong, mostly it can still working on car. so you'd better write the proper security byte.
    if for other modeules the chip is unsecured means no need set security.
  18. #2126
    habbyb's Avatar
    Romania
    Hello Samic , please tell me what's happening with the factory I ordered the adapters XDPG30CH two months ago, it is now taking a long time . http://www.vvdishop.com/wholesale/xh...-adapters.html
  19. #2127
    Jun 2013
    Separat Upgrade kit soft or inside VVDI2 or Keytool.
    Upgrade Kit is denied by Microsoft Antivirus. It is actually deleted by the AntiV.
    Earlier it worked out when deactivating the "Live protection" in Settings.
    Then install/run software, and do what was intended.
    Now it does not even work when then "Live protection" in Settings is deactivated.
    Need to uninstall Antivirus, run Upgrade Kit. And then install Antivirus again.
    Also possible just to download with the links which is released at DK.
    Then it is not a problem.
    But maybe problem with Keytool software? Then the only solution was to remove the AntiV.
    Anyone else have some experience or other solutions?
  20. The Following User Says Thank You to Weasel3 For This Useful Post:
    peugeotexpert (24th March, 2018)
  21. #2128
    is there any plan to add mevd ecu flash reading? since we can read eeprom in boot mode i guess it should not be too difficult to add flash support?
  22. #2129
    Apr 2015
    Quote Originally Posted by habbyb View Post
    Hi friend, Xhorse have no website for sale. you can directly check with dealer seller.
    i already talked with this website manager to take care.if any problem let me know, i will try my best.
  23. The Following User Says Thank You to Samic For This Useful Post:
    habbyb (23rd March, 2018)
  24. #2130
    Apr 2015
    Quote Originally Posted by phatty123 View Post
    yes, we will find solution and add to VVDI PROG.
