Page 144 of 295 FirstFirst ... 4494134139140141142143144145146147148149154194244 ... LastLast
Results 2,146 to 2,160 of 4422
Thread: VVDI PROG
  1. #2146
    Hampshire
    Just received my adapter sets from sugar xhorseshop, and had a play with vitto w639, read st in 20 sec, wrote new file in under a minute,they seem to be well made. watch out there are 2 adapter sets for these! I used 0L02M (adapter) from the menu.
  2. The Following User Says Thank You to nazz2 For This Useful Post:
    p1et (28th March, 2018)
  3. #2147
    I try many time not success it have error cpu not connect
    will try again today
    thank
  4. #2148
    Quote Originally Posted by louis21 View Post
    Yes,support.In the 2-MCU,RENESAS-R8C
    thank
  5. #2149
    Quote Originally Posted by niwat_spp View Post
    thank
    have error
    [2018-03-29 19:13:12] : Change to 2-MCU-->RENESAS-R8C-->R5F21548G
    [2018-03-29 19:13:14] : Select <D-FLASH>
    [2018-03-29 19:13:22] : Select <D-FLASH>
    [2018-03-29 19:13:29] : Check Device...
    [2018-03-29 19:13:30] : 12V Power Adaptor connected
    [2018-03-29 19:13:30] : Initialization device...
    [2018-03-29 19:13:32] : Initialization success!
    [2018-03-29 19:13:33] : Initialization chip...
    [2018-03-29 19:13:35] : Try Security Bytes 00000000000000
    [2018-03-29 19:13:35] : Security pass success
    [2018-03-29 19:13:35] : Start communication...
    [2018-03-29 19:13:35] : Read length:0x1000
    [2018-03-29 19:13:35] : Reading...(0%)
    [2018-03-29 19:13:35] : Read Error
    try Erase no problem
    2018-03-29 20:25:34] : User select yes
    [2018-03-29 20:25:34] : Check Device...
    [2018-03-29 20:25:36] : 12V Power Adaptor connected
    [2018-03-29 20:25:36] : Initialization device...
    [2018-03-29 20:25:36] : Initialization success!
    [2018-03-29 20:25:37] : Initialization chip...
    [2018-03-29 20:25:38] : Try Security Bytes 00000000000000
    [2018-03-29 20:25:38] : Security pass success
    [2018-03-29 20:25:38] : Start communication...
    [2018-03-29 20:25:38] : Erase length:0x1000
    [2018-03-29 20:25:38] : Erasing...(0%)
    [2018-03-29 20:25:38] : Erasing...(25%)
    [2018-03-29 20:25:38] : Erasing...(50%)
    [2018-03-29 20:25:38] : Erasing...(75%)
    [2018-03-29 20:25:39] : Erasing...(100%)
    [2018-03-29 20:25:39] : End communication...
    [2018-03-29 20:25:39] : Operation success
    And try write it no problem
    [2018-03-29 20:27:04] : Start communication...
    [2018-03-29 20:27:04] : User select yes
    [2018-03-29 20:27:04] : Erase length:0x1000
    [2018-03-29 20:27:04] : Erasing...(0%)
    [2018-03-29 20:27:04] : Erasing...(25%)
    [2018-03-29 20:27:04] : Erasing...(50%)
    [2018-03-29 20:27:04] : Erasing...(75%)
    [2018-03-29 20:27:04] : Erasing...(100%)
    [2018-03-29 20:27:04] : Write length:0x1000
    [2018-03-29 20:27:04] : Writting...(0%)
    [2018-03-29 20:27:05] : Writting...(25%)
    [2018-03-29 20:27:05] : Writting...(50%)
    [2018-03-29 20:27:05] : Writting...(75%)
    [2018-03-29 20:27:05] : Writting...(100%)
    [2018-03-29 20:27:05] : End communication...
    [2018-03-29 20:27:05] : Operation success
    have solution?
    thank
  6. #2150
    claudio35's Avatar
    Chile
    Quote Originally Posted by Samic View Post
    350803 we tested and supported. could you take a clearly photo about your chip.
    also post here software screenshot which option you selected.
    I will try again, when I have another chip 35080 3, now I do not have
  7. #2151
    Apr 2015
    have error
    have solution?
    thank
    Thanks for your feedback, we will arrange one module with R5F21548G chip for testing first, any process will post here.
  8. #2152
    Dec 2011
    Nottingham
    we have to find those unit for check first, if you can provide us we can add fast.
    for BMW 160DOWT its difficult to support.
    Originally Posted by automotrizVIP
    hello friend @samic any chance to add this type of reference with proper reading
    Ecm Renault.....
    Renault
    Valeo V40/V42 (SH7058/1024KB)
    Sagem 3000 (SH7055/512KB)
    EMS3110 (TC1766/1504KB)
    Logan, Sandero, Fluence, Megane, Almera EMS3120 (TC1738/2048KB)
    Duster, X-Ray EMS3125 (TC1782/2560KB)
    Clio 4 1.6T EMS3150 (TC1767/2048KB)
    Reading, writing, checksum correction.
    Bmw eeprom soic 8
    Eeprom 160DOWT ....
    Thank you
    @Samic
    My company has 10000+ different ECU and modules in stock, if you want anything we have in stock I can send to you for your testing purposes. Feel free to send me a Skype/pm and I will happily oblige.
    Always happy to help where I can
  9. The Following 6 Users Say Thank You to Autowave For This Useful Post:
    automotrizVIP (30th March, 2018), cfgebel (31st March, 2018), habbyb (1st April, 2018), Samic (31st March, 2018), u.s (31st March, 2018), vasiliev7719 (2nd April, 2018)
  10. #2153
    Oct 2016
    Scotland
    Anyone have any pointers for me, i'm trying to read a MC68HC05E6 (0F82B) on a PSA immobox (Siemens), Part number: 9629677480
    When i try to read the chip it'll show initialise success, shows 0% and then read error.
    Even tried removing the chip from the PCB and get same results (but maybe this chip needs to have the external oscillator circuit).
    There doesn't seem to be any option in the software to change the frequency.
    I'm using the V3 MCU cable, and latest software. Connections to the chip as per diagram in vvdi-prog software - checked & double checked
    Thanks in advance
  11. #2154
    hi
    bmw f10 2010 cas 4 5m48h BACKUP dflash I read all FF . what it is possible to make??
  12. #2155
    Feb 2016
    Double post
    +thanks if I helped you!
  13. #2156
    Feb 2016
    Quote Originally Posted by emtec3 View Post
    hi
    Did you checked connections? Id is normal to be FF but reading should contain data. Did you tried to read it with another programmer before? Does the car starts now? Please provide some context...
  14. #2157
    no, other programmator I didn't try, p-flash was read normally, and d-flash one ff
  15. #2158
    it is possible to make that worked with other cas4?? except purchase of new cas4 from the dealer
    I read isn with ecu msv90, still there is a suspicion that p-flash too bad
  16. #2159
    prompt marking of the diode a photo it is specified by an arrow, and can eat at whom d-flash and p-flash from this cas4
  17. #2160
    Apr 2015
    Quote Originally Posted by WRX 14 View Post
    Thanks in advance
    friend, today later will PM send you a beta version to this HC05E6 option.
    after test let me know the result.
  18. The Following User Says Thank You to Samic For This Useful Post:
    WRX 14 (2nd April, 2018)
