Page 15 of 295 FirstFirst ... 510111213141516171819202565115 ... LastLast
Results 211 to 225 of 4422
Thread: VVDI PROG
  1. #211
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Looks crazy, I need tool for working not for testing. How you can trust tool if 50% not working or not tested by developers? How you can take client car for repair if you not trust your tool working? Functions of this tool looks good, but why buy to play? I think need buy to work?
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
  2. The Following User Says Thank You to Saulius Saulius For This Useful Post:
    ecumix (12th June, 2017)
  3. #212
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by Samic View Post
    VVDI PROG latest version V4.1.4 update:
    in <1-EEPROM&FLASH>-><INTEl>(Need the TB28FXXX adapter)
    Samic, will you add later 29FXXX flash?
    If I helped you know what to do..
  4. #213
    Nov 2014
    Today
    recieved my VVDIPROG.
  5. #214
    Default vvdi prog CAS4-5M48H reading problem
    Hello samic ,
    I got the machine two days ago, I tried to read CAS4-5M48H but kept failing, I have the latest software(4.1.4), connected according to the picture content, and according to the explanatory on the software ,I tried but Without success!
    Would you please explain to me what I was doing wrong,
    Attaching images
  6. #215
    Aug 2010
    Herts, UK
    Quote Originally Posted by key4man View Post
    Hello samic ,
    Attaching images
    You bought wrong tool! Maybe later this tool will be good, but now it looks like beta version for testing... and broking customer cars...
  7. The Following User Says Thank You to Saulius Saulius For This Useful Post:
    key4man (19th December, 2015)
  8. #216
    I buyed also And killed cas4
    bad or not good developped tool
  9. #217
    bearheroes's Avatar
    Dec 2011
    Quote Originally Posted by garageozcar View Post
    Why you think Xprog and even more MDPEvo are so expensive???
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  10. The Following User Says Thank You to bearheroes For This Useful Post:
    Siham (19th December, 2015)
  11. #218
    Quote Originally Posted by Saulius Saulius View Post
    Good morning my friend
    You are right my friend, perhaps later will be a good programmer, we will continue to be a research field for manufacturers, the CAS4-5M48H , I buy it from spare parts and that my luck, no way for me to try it on customers cars.
    Thanks anyway
  12. #219
    Siham's Avatar
    Jul 2014
    Key4man ,what kind of diagram connection you are using ? because there is 4 kind of diagram.
    And i think the first one is wrong cause if you look at the masl its 1l15y and not 5m48h .
    Also did you cutted the 2 wires?
    I see many videos of this tool and it seam to be ok for cas ,but it's on videos ......
    Keep us update .
    No thank , no HELP .
  13. #220
    Default vvddi prog
    Hello everyone
    This is what appears in the software for the cas4 , for me, personally I could not read it.
    Security Byte Address: 0xFFF0F
    Unsecured State: 0xFE(xxxx xx10)
    Please use "CAS4-5M48H-BACKUP" option backup the D-FLASH and P-FLASH data first!
    Steps:
    1.Use "Reset Sec"unlock chip, the original security byte displayed in the window below
    2.Read or write D-FLASH and P-FLASH data, the command can be executed many times
    3.Use "Set Sec", input the security byte read from step 1
    Mask:0M22E ID:CC80
    Mask:1M22E ID:CC80
    Mask:2M22E ID:CC82
    Mask:0M48H ID:CC90
    Mask:1M48H ID:CC91
    Mask:2M48H ID:CC92
    Mask:3M48H ID:CC93
    Mask:4M48H ID:CC94
    Mask:5M48H ID:CC94
    Mask:0N35H ID:CC95
    Mask:1N35H ID:CC95
  14. #221
    Dec 2015
    Hi mates
    anybody knows where we can find special forum for vvdi programmer sl that we can get luve support
  15. #222
    Mario3's Avatar
    Dec 2014
    Quote Originally Posted by Nassreddine84 View Post
    Hi mates
    this is the best there is, you wont find more/better support anywhere
  16. The Following 2 Users Say Thank You to Mario3 For This Useful Post:
    Atex31 (20th December, 2015), stickmuon (22nd December, 2015)
  17. #223
    Apr 2015
    Quote Originally Posted by AndyCZ View Post
    friend,maybe will add this function later.
  18. The Following User Says Thank You to Samic For This Useful Post:
    AndyCZ (22nd December, 2015)
  19. #224
    Maartinj's Avatar
    Nov 2010
    Guys
    Any1 can help me to find out a right way to connect ECLK and GND-C to that CPU ?
  20. #225
    bearheroes's Avatar
    Dec 2011
    Eclk is probably extal. Gnd-c is ground. Check xprog to compare pin numbers.
  21. The Following User Says Thank You to bearheroes For This Useful Post:
    Maartinj (21st December, 2015)
