Page 150 of 295 FirstFirst ... 50100140145146147148149150151152153154155160200250 ... LastLast
Results 2,236 to 2,250 of 4422
Thread: VVDI PROG
  1. #2236
    habbyb's Avatar
    Romania
    Hello , Samic It is the best moderator , he helped me too , I thank him very much .
  2. #2237
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Samic want to ask you about
    hc08az60 mcu's
    vvdi reads 2 eeproms separately. Is there any chance to add option to read this mcu is one packadge 1024kb. As now its separate 512kb. in some immo work i need 1024kb.
  3. #2238
    Apr 2014
    Spain
    Hi to all. I cloned ECU PSA DCU102 micro ST10F276 successfully.
    Attach PinOUT.
    Regards.
  4. The Following 2 Users Say Thank You to danielif For This Useful Post:
    habbyb (10th May, 2018), rob h (10th May, 2018)
  5. #2239
    Apr 2015
    Quote Originally Posted by drugowaz View Post
    hc08az60 mcu's
    not sure whether can add in one data package as 1024kb, we will try first, if we can figure it out sure will add.
  6. #2240
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Xprog has this function it reads full 1024 size
  7. #2241
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    hc08az60 mcu's
    MC68HC08AZ60 have 1024 kb size memory area ??? are sure ?
    many thanks to friend kevfield
  8. #2242
    p1et's Avatar
    Oct 2013
    Anyone tried to read Volvo CEM with 2x 9s12xdt256 1l15y?
    With Lonsdor connections VVDI read right one both eeprom and flash every time but cannot read the left one -every time 'chip not connected' Strange because the Lonsdor manual say connections are exact the same, but it does not work for me with left mcu.
    So anyone tried and succeed in reading both MCUs?
  9. The Following 2 Users Say Thank You to p1et For This Useful Post:
    habbyb (11th May, 2018), mikajna (13th May, 2018)
  10. #2243
    hc08az60 eeprom is 1024 bytes total.
    Divided into eeprom1 and eeprom2, each 512bytes.
    Just merge them with any hexeditor
  11. #2244
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by exe123 View Post
    bytes....yes thats right
  12. #2245
    habbyb's Avatar
    Romania
    Quote Originally Posted by p1et View Post
    Hello , it would be great the team Xhorse to solve this problem will we need this option .
  13. #2246
    p1et's Avatar
    Oct 2013
    Tried X-Prog and same exact situation. Right one read eep & flash perfect, left no comms with MCU. I will try with Lonsdor KPROG-2 but they did not include any adapter for connecting to MCU so need to use other cables. Don't want to solder straight on KPROG pins.
  14. The Following User Says Thank You to p1et For This Useful Post:
    habbyb (12th May, 2018)
  15. #2247
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I tried this. Not worked
  16. #2248
    drugowaz's Avatar
    Mar 2015
    Lithuania
    So ring poins around mcu and no problem. You will find proper connections. I did bunch of these no problem both mcu
  17. #2249
    p1et's Avatar
    Oct 2013
    I tried and same situation. Right one work flawless and left no comms. If you succeed in reading both, then I don't know what is going on... Maybe MCU is damaged? This CEM is from scratch for testing purposes.
  18. The Following User Says Thank You to p1et For This Useful Post:
  19. #2250
    habbyb's Avatar
    Romania
    Hello , maybe MCU it's corrupt mast by read something FFFFFF or posibil pcb is damage and can read anymore .
