Page 153 of 295 FirstFirst ... 53103143148149150151152153154155156157158163203253 ... LastLast
Results 2,281 to 2,295 of 4422
Thread: VVDI PROG
  1. #2281
    Just read p-flash and compare with your backup
  2. The Following User Says Thank You to exe123 For This Useful Post:
    doud77 (14th May, 2018)
  3. #2282
    Usa
    Quote Originally Posted by automotrizVIP View Post
    https://youtu.be/8rbu8J4xTEs...
    Why not use the option directly. This was added to the menu very much.....
    https://youtu.be/677aFyBoyoE
    But the video is about an FRM 3!
    I have a FRM 2 / MC9S12XDT256
    And with VVDI Type 8 - Other this is not available.
  4. #2283
    Pflash was the same as the backup.
    Eventhough, set everything stock....and BCM still out o order.
    Damned!!!
  5. #2284
    Quote Originally Posted by doud77 View Post
    Damned!!!
    Either P-Flash was not correctly read or you have a HW issue. You have soldered back the resistor and restored the track you have cut?
  6. #2285
    Quote Originally Posted by exe123 View Post
    Maybe...HW issue....maybe bad vvdi wires....maybe I don't know
    Yes all components were soldered back
  7. #2286
    habbyb's Avatar
    Romania
    Damned!!!
    I made comparison , I think P-Flash he's corrupt because he has too many FFFFFFF , anyway it should be different bat too many FFFFFFFF , see foto .
  8. #2287
    Apr 2015
    Quote Originally Posted by p1et View Post
    Anyone tried to read Volvo CEM with 2x 9s12xdt256 1l15y?
    With Lonsdor connections VVDI read right one both eeprom and flash every time but cannot read the left one -every time 'chip not connected' Strange because the Lonsdor manual say connections are exact the same, but it does not work for me with left mcu.
    So anyone tried and succeed in reading both MCUs?
    Thanks for your feedback, we will find this unit and recheck again, any pocess will post here
  9. #2288
    Apr 2015
    I am facing a problem in the use of vvdi prog, and I need your support please.
    CAR: porsche panamera gts my2013
    MODULE: BCM (continental P/N 7PP.907.064.GA)
    MCU: freescale 9s12xep100 mask 5M48H
    I had to extract the D-flash to add a key, so I have:
    1-wired the vvdi prog on the bcm as picture in soft
    2-made backup of DFLASH and PFLASH file (IMMOBILISER>porsche>BCM-5M48H-BACKUP)
    3-put back the bcm in the car: started OK
    4-removed back bcm and wired it to vvdi prog again
    5-made backup again (same file)
    6- switched to IMMOBILISER>porsche>BCM-5M48H-R/W/UNLOCK
    7-pushed "reset sec" button but finished with a failed
    8-pushed again "reset sec", and same fail
    9-switched to IMMOBILISER>porsche>BCM-5M48H-FORCE-UNLOCK
    10-pushed "reset sec" button and it finished success (decrypt)
    11- switched to IMMOBILISER>porsche>BCM-5M48H-R/W/UNLOCK
    12- read d-flash again and compared to backup (same files)
    13-write my mod DFLASH
    14-pushed "set sec"
    15- removed wires and install BCM back to car=> no reaction of the car (bricked)
    16- removed BCM and reput original DFLASH same procedure as before
    17- put BCM in car same situation=>no reaction of the car
    Here I need your help please because I don't know what's going wrong!
    thanks for supports guys!!
    checked your backup Dflash and Pfalsh dump should be work. you can re-write your new Dflash and backup Pflash, then Set Sec as '7D'.
    if put back to vehicle still with problem, should be hardware issue, maybe soldering issue.
  10. #2289
    Quote Originally Posted by Samic View Post
    Already done all what you advice to do,, but unfortunately I am still stuck at same point.
  11. #2290
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Check components you desoldered and track you cut. Ive read write panamera s 2016 no problem
  12. #2291
    jodge's Avatar
    Mar 2017
    Fiat IMM100.01 immobox Marelli
    MC68HC908AZ32
    Mask : 1K59H
    read-write ok
  13. The Following 2 Users Say Thank You to jodge For This Useful Post:
    lalaina74 (16th May, 2018), p1et (19th July, 2021)
  14. #2292
    Mar 2009
    4.7.0 mega download link isnt working. File no longer available. Wow gotta get up earlier I guess.
  15. #2293
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by madaxe View Post
    https://mega.nz/#!NAsD2KBT!I99epC-rH...-Xl9pJ1R6Y/url
  16. The Following User Says Thank You to Maartinj For This Useful Post:
    Zapp (30th May, 2018)
  17. #2294
    Quote Originally Posted by drugowaz View Post
    Already done bro, but seen nothing.
  18. #2295
    drugowaz's Avatar
    Mar 2015
    Lithuania
    If you backuped files. Than write them again. Read again. In you checked all components and ringed cirquit with multimeter and all good. I had other panamera after put back components and restore track. Car dead just relay clicking in bcm. Than resolder all again. Removed crystal and redone track again tested with multimeter and car was alive again.
  19. The Following 2 Users Say Thank You to drugowaz For This Useful Post:
    doud77 (17th May, 2018), habbyb (17th May, 2018)
