Page 155 of 283 FirstFirst ... 55105145150151152153154155156157158159160165205255 ... LastLast
Results 2,311 to 2,325 of 4422
Thread: VVDI PROG
Hybrid View
    ttzag's Avatar
    digital-kaos
    Kessy (steering lock) for audi a6 and Q7 mask 1L59W not work if you select it from immobilizer ..it's read if you select 9s12xxx from mcu item
    Sent from my HTC U11 using Tapatalk
    Actions speak louder than words
  2. The Following 2 Users Say Thank You to ttzag For This Useful Post:
    habbyb (16th June, 2018), mickye_dj (16th June, 2018)
  3. #2
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by ttzag View Post
    can you show the screen from immo menu ? i think there only 93C86 reading choice
    many thanks to friend kevfield
  4. The Following User Says Thank You to daxxer For This Useful Post:
  5. #3
    habbyb's Avatar
    Romania
    Hello mate , read ok 4-immo-audi , check it out dump .A6ELV.rar
  6. #4
    ttzag's Avatar
    digital-kaos
    Steering lock for a6 and q7 no c86 ...only 9s12xxx
    habbyb's Avatar
    Romania
  8. The Following User Says Thank You to habbyb For This Useful Post:
    daxxer (16th June, 2018)
  9. #6
    ttzag's Avatar
    digital-kaos
    Quote Originally Posted by habbyb View Post
    Yes as i connect
    But when i select it under immobilizer/audi /j518/1L59w.
    Its read only id and can't read eep.
    When i select mcu / 9s12xxx/secure. It's read id and eep
  10. #7
    Apr 2016
    I tried read
    mcu 9s12dg128 in Chrysler, Jeep immobox
    no succes
    carprog clone read ok
  11. #8
    i try to read R5F64219 - not work
  12. #9
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    I think you have to connect the clock signal too
  13. #10
    KILL_THE_IMMO's Avatar
    spain
    hi
    temic immobox foe sprinter 4l52h mcu fail to read
    2018-06-18 10:59:37] : Change to 4-IMMOBILIZER-->BENZ-->SPRINTER-IMMOBOX(2002-2005)
    [2018-06-18 10:59:38] : Select <EEPROM>
    [2018-06-18 10:59:56] : Select <Chip Config>
    [2018-06-18 11:00:04] : Check Device...
    [2018-06-18 11:00:05] : 12V Power Adaptor connected
    [2018-06-18 11:00:05] : Initialization device...
    [2018-06-18 11:00:08] : Initialization success!
    [2018-06-18 11:00:09] : Initialization chip...
    [2018-06-18 11:00:09] : Try manual set frequency
    [2018-06-18 11:00:10] : Try Frequency failed Chip unconnected
    any help please???
    --------HELP OTHER TO BE HELPED--------------
  14. #11
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by KILL_THE_IMMO View Post
    hi
    any help please???
    tested now on 0J66D, the same MCU read steps and success
    check your soldering and settings... must work when mcu are not dead
  15. The Following User Says Thank You to daxxer For This Useful Post:
    taxo1965 (19th June, 2018)
  16. #12
    Can someone please post new link to v4.7.1
    Old link no longer works. Thanks
  17. #13
    Jun 2016
    Quote Originally Posted by testit34 View Post
    This is working: https://mega.nz/#!d3gXTSQK!cDVuuCeAY...sg9eFKsiGsD-Fs
  18. The Following 2 Users Say Thank You to crazylou2017 For This Useful Post:
    daxxer (19th June, 2018), taxo1965 (19th June, 2018)
  19. #14
    spain
    I READ IT with mtrk so mcu is fine
  20. #15
    Feb 2013
    Hello.MC9S08DZ60 chevrolet,VVDI Prog does not read correctly.Please correct.Thanks
    Later, I'll read Orange 5 and lay out
