Page 159 of 295 FirstFirst ... 59109149154155156157158159160161162163164169209259 ... LastLast
Results 2,371 to 2,385 of 4423
Thread: VVDI PROG
  1. #2371
    KILL_THE_IMMO's Avatar
    spain
    I READ IT with mtrk so mcu is fine
    --------HELP OTHER TO BE HELPED--------------
  2. #2372
    Feb 2013
    Hello.MC9S08DZ60 chevrolet,VVDI Prog does not read correctly.Please correct.Thanks
    Later, I'll read Orange 5 and lay out
  3. #2373
    Apr 2016
    Ews4 read ok
  4. #2374
    Feb 2013
    W169 A KLASS 2007 EZS read eeprom bad
    Reat VVDIprog V4.70\71 V1 (ST12)
  5. #2375
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I think something with your tool or cable bdm
    Dz60 reads good tested on cim.
    But it reads 2 separate areas of eeprom thats why its not accept your dump.
    Im telling you 100% because ive done antara immo box too.
    You must make one eeprom of both you read and just than load file.
    Orange reads whole dump instantly immo hpx.
    St12 also never was problem
  6. The Following User Says Thank You to drugowaz For This Useful Post:
    taxo1965 (29th June, 2018)
  7. #2376
    Feb 2013
    Hello.Why does she read in this format?It is necessary to manually transfer the bytes to the normal format.Thanks
  8. #2377
    Hampshire
    What is the correct procedure to read+write range rover kvm 9s12? i pressed read id, then read dflsh+pflah+pof, but what is the reset security botton for? if you press it ,it comes up with loosing data warning ,are you sure? and then seurity unlock, the guy from mart tool puts fe to write to the mcu, a bit conusing a proper procedure, is greatly apreciated.
  9. #2378
    rob h's Avatar
    May 2011
    Here is a vid, in the middle, there is the xprog procedure displayed. Steps how to work with secured mcu. (JLR KVM unlock)
    It might clearify things, https://www.youtube.com/watch?v=quyxHyV_UWc
  10. The Following 3 Users Say Thank You to rob h For This Useful Post:
    daxxer (30th June, 2018), habbyb (1st July, 2018), nazz2 (30th June, 2018)
  11. #2379
    Hampshire
    Better explanation on this video, in comparison to the chinese vvdi videos , so correct me if i am wrong , if the vvdi detects secure /locked 9s12, it has to be unlocked first, i think the warning with regards to the"data deletion" when unlocking the mcu probably it refares to the securty data!! also no explaton when unlocking the mcu with vvi , they write "FE", a bit more relived now thanks.
  12. #2380
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Theres no more to clear. If its secured you go trough reset security. Get sec bytes,after write set security with bytes given when read. Its same as you would done bmw or porsche secured mcu.
  13. The Following User Says Thank You to drugowaz For This Useful Post:
    habbyb (2nd July, 2018)
  14. #2381
    Hi! Can somebody provide link for V4.7.2 ?
  15. #2382
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by darkoman View Post
    https://mega.nz/#!BRUmTCiD!NR-5ppntp...R68lKh-PfA/url
  16. The Following 2 Users Say Thank You to Maartinj For This Useful Post:
    darkoman (2nd July, 2018), polys123 (26th July, 2018)
  17. #2383
    Thank you Maartinj, but link you provided opens download for
    VVDIProg4.7.1 .rar
  18. #2384
    sv2hqx's Avatar
    Jun 2014
    Updater from is working
    You can update from application
    Actually....... where do you see 4.7.2??
  19. #2385
    Quote Originally Posted by sv2hqx View Post
    Here it is...
