Page 162 of 295 FirstFirst ... 62112152157158159160161162163164165166167172212262 ... LastLast
Results 2,416 to 2,430 of 4422
Thread: VVDI PROG
  1. #2416
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by tferenc View Post
    I am a bit disappointment about buying the VVDI prog.
    1.On that week it kills a W203 EIS, a Volvo dash, and a lot of CAS2 (I have seen it on many forums.)
    2.It not supports the older NEC 78xx (for example 2001 agila dash, while a 80 USD programmer it supports)
    VVDI Prog is one of the best programmer to work with MB & BMW. Well if someone kill CAS2 with it then maybe do not play with electronics at all...
  2. The Following 7 Users Say Thank You to p1et For This Useful Post:
    CaioW (9th August, 2018), daxxer (6th August, 2018), lpf01 (8th August, 2018), mickye_dj (17th August, 2018), offsystem (4th August, 2018), ttzag (4th August, 2018), weza247 (9th August, 2018)
  3. #2417
    Feb 2016
    United Kingdom
    Quote Originally Posted by p1et View Post
    p1et,
    what about CAS3+ and CAS4?
  4. #2418
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by BmwMerc View Post
    p1et,
    I did not have a chance to work with CAS4 yet but I know people who are very good in this business and they use VVDI Prog for CAS4 so I can recommend. CAS up to 3+ is no problem. Most important is making a good wires connection. Some people do not solder carefully and then blame the tool.
  5. The Following 3 Users Say Thank You to p1et For This Useful Post:
    BmwMerc (4th August, 2018), lalaina74 (5th August, 2018), sqlkarol (5th August, 2018)
  6. #2419
    Faraday's Avatar
    May 2012
    The dark side of the moon
    cas3 and 3+ ok did few with vvdi prog.
  7. The Following 2 Users Say Thank You to Faraday For This Useful Post:
    BmwMerc (4th August, 2018), sqlkarol (5th August, 2018)
  8. #2420
    May 2015
    Cas3, cas4 all okay with vvdi. Soldering is most important.
    Sent from my SM-G950U using Tapatalk
  9. The Following 2 Users Say Thank You to Nymike For This Useful Post:
  10. #2421
    Feb 2011
    PL
    Real 4.7.3 update
    BR
  11. The Following 5 Users Say Thank You to sqlkarol For This Useful Post:
    automotrizVIP (18th August, 2018), daxxer (9th August, 2018), karageorgos (6th August, 2018), rocris (19th August, 2018), tehnosoftex (18th August, 2018)
  12. #2422
    Nov 2015
    Have somebody tried to read M30855FH/M30855FW in system with VVDI prog?
    Thank you!
    "thanks" if i helped you is really appreciated
  13. #2423
    Oct 2013
    Default MB90F546
    I read MCU Fujitsu MB90F546GS flash. Read ok. Trying rewrite flash is problem. Samic is bug?
  14. #2424
    Mar 2017
    Colombia
    hi mate, there are problems in the honda airbag mcu.
    Mcu spc .
    you should verify.
    Read ok
    Write bad, the writing is very fast and it remains in error he mcu..
    @Samic.
    please repair these options. you could damage modules.
    Thank you my friend
    WINNER THE LOSER
  15. #2425
    CaioW's Avatar
    Oct 2015
    Everywhere
    CAS and FEM work like a charm with VVDI PROG.
    Have done alot of them and 0 problems.
  16. The Following 4 Users Say Thank You to CaioW For This Useful Post:
    habbyb (10th August, 2018), Maartinj (9th August, 2018), p1et (12th August, 2018), sqlkarol (10th August, 2018)
  17. #2426
    Member zolee33's Avatar
    Mar 2016
    Hungary
    I tried to read 3 another Fujitsu MB90F546GS, all OK.
    But i am not able to rewrite, error when erasing.
    Whats wrong? Need pin lift?
  18. #2427
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by zolee33 View Post
    what part of ROM you need erase ??
    many thanks to friend kevfield
  19. The Following User Says Thank You to daxxer For This Useful Post:
    tferenc (13th August, 2018)
  20. #2428
    Romania
    Quote Originally Posted by daxxer View Post
    He want to write the flash from another unit because it is got corrupted by trying to remove the Component Protection with FVDI.
  21. #2429
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friends
    Someone here have success to read this MCU MC68HC805P18 immobox MItsubishi with VVDI, if yes i'll appreciate pinout please!!!
    Cheers
    Press "THANKS" button. just one click, CHEERS
  22. #2430
    kautuvera's Avatar
    i want to make a full dump (not only the 512bytes eprom) from a EWS3 MCU (0D46J) without EWS3 adaptor
    A PLCC test clip should be good enough to establish the connection to the programmer.
    But what about the connections on the board, i think i have to cut some wires on the pcb to get full access to the mcu, right?
    Can somebody help?
    regards
