Page 166 of 295 FirstFirst ... 66116156161162163164165166167168169170171176216266 ... LastLast
Results 2,476 to 2,490 of 4422
Thread: VVDI PROG
  1. #2476
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by jodge View Post
    i'm just curious guys do you removing the can filter (if fitted) from the cas4 before the backup or not?
    No need to remove it!
  2. The Following User Says Thank You to sniegavirs For This Useful Post:
    jodge (6th September, 2018)
  3. #2477
    Apr 2016
    uk
    Should be same as the beetle listed there.
    I've done a TT 2001 and I used the connection from VW beetle ..
    Quote Originally Posted by fytfh View Post
    need pinout connection with vvdi prog for instrument cluster on audi TT 2000year
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
  4. #2478
    Apr 2015
    Quote Originally Posted by ibratex View Post
    i manager to read now i have another problem file is 32.2 kb size . 36.0 size on disk and when i insert the file to tango says size error ..please help me experts
    Sent from my SM-G935F using Tapatalk
    friend, thanks for your feedback. in fact FLASH :0x0000~0x7FFF EEPROM:0x8000~0x80FF
    VVDI PROG read and save both data, so you can manually delect EEPROM size.
  5. #2479
    Hanukkah's Avatar
    When will VVDI support reading and writing of Infineon SAK XC2765-72 mcu?
  6. #2480
    Apr 2009
    RS, BRASIL
    i see xhorse selling 2 adapters for eprom 28fxxx and 29fxxx, can i use 28fxxx adapter ffor readinf 29fxxx? or i need 2 adapters?
  7. #2481
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by valdirld View Post
    t28 is bigger and insert socket
    t29 is smaller
    inc T29 you get 2 PCB and one base plate, (this is complet set)
  8. #2482
    Apr 2009
    RS, BRASIL
    yes, i see thats bigger, but i know that i can replace 28f with 29f, my trouble, if i bougth the 28f socket, can i read 29f with?
  9. #2483
    Oct 2017
    Hungary, Budapest
    Anyone know some details about BMW Key Unlock issue, with VVDI prog / key tool? I'm trying to program unlocked key to FEM, but keep failing. Somewhere read it's because old key firmware which uploaded during unlock and thats not compatible with ews5...
  10. #2484
    Jul 2008
    romania
    i have renewed a cas4 key and worked on another cas4+!!! but i did not try on fem ...
  11. #2485
    Renesas R7F701033 - read ok, but if you try write dflash then always stop at erase step - this is lottery - from 10% to max. 35% of erase cycle and stops
  12. The Following User Says Thank You to gif_kuba For This Useful Post:
    sniegavirs (11th September, 2018)
  13. #2486
    Feb 2013
    RANGE ROVER 18F6620 IMMO 2008
    Read-write OK.Thanks
  14. The Following 2 Users Say Thank You to taxo1965 For This Useful Post:
    habbyb (12th September, 2018), sniegavirs (12th September, 2018)
  15. #2487
    Aug 2016
    i have VVDI Prog with OEM EWS 3 Adapter.
    Read works after trying serveral times and write works after trying more serveral times.
    What is here the problem?
  16. #2488
    Apr 2016
    uk
    You are lucky...
    My vvdi prog just killed a 0d46j ews3...
    Quote Originally Posted by Emmy View Post
  17. #2489
    Apr 2009
    RS, BRASIL
    @SAMIC
    CAS3++ 0L15Y could not read with, it read id but cannot read mcu, read ok with R270, please verify
  18. #2490
    @SAMIC
    You are doing something wrong, did it correctly with my ex e91 car, had istap cas3++ 0L15Y.
    Enviado desde mi SM-G960F mediante Tapatalk
