Here you go,
hello i need to read this dash for honda mb91f060bs do you have anyone info pin out pleASE unnamed (1).jpgunnamed.jpg
Here you go,
alclot (13th December, 2018)
this is with carprog;
tell me does vvdiprog airbag PSA D70F3624?
honda mb91f060b try this for VVDI Prog
edit on 4.7.7 is this dashboard in manula and no need 1kOhm resistor
So bridge 1kohm:
red vcc pin 53
brown duout pin 91
Or are the pins in your picture different?
Would simply 1kohm bridging of the bdm points red and brown be more easy?
alclot (17th December, 2018), brane0001 (1st January, 2020), Levanime (16th December, 2018), PocketHero (16th December, 2018), Shakeelbhugeloo (14th June, 2021), Siham (19th December, 2018)
Anyone have a virging pcf file that i can use to renew used bmw fem remotes with vvdi prog? its pcf 7953vc1900.
I attached a photo of the remote in question, and i know Barracuda tool can renew those and have connection diagram.
Oh NO!! I hope my VVDI Prog is not broken. Yesterday I connected up a CAS2 and tried to read. Program started verifying device, then I heard USB disconnect ding! Then it tried chip verify again usb disconnected then it hanged. Green light on tool did not flash. So I thought it was something with my computer.
Took another trusted laptop I have used before, same thing!!! Something has happened to it and I don't know what. It seems to loose connection with computer while processing a command. I got "USB port too much voltage" error with the first laptop. Second one has no such error but the disconnect still occurs.
Any ideas?
Just to clarify I had increased the length of the thin wires as they were wearing off (But not +, - and the shrouded pair). I tried both cases with original wire length, same issue
Last edited by Willisodhiambo; 18th December, 2018 at 06:46 AM. Reason: Additional info
hi , what is the status of your device when connect to computer , the yellow led flash or not , pls do not extend the cable as you want ,
and for that device , if the yellow led not flash , you need contact to the vendor who sold you that and ask the vendor to help you return back the vvdi prog to China for repair ,
Does VVdi support A3 2011 Micronas dashboards yet ?
IS GOOD TOOL
