Page 190 of 290 FirstFirst ... 90140180185186187188189190191192193194195200240 ... LastLast
Results 2,836 to 2,850 of 4348
Thread: VVDI PROG
  1. #2836
    Why isn't there a mileage change option for cas4? Surely it should be added
    Sent from my SM-N960F using Tapatalk
  2. The Following User Says Thank You to javyb For This Useful Post:
    teerak2uk (19th July, 2020)
  3. #2837
    Quote Originally Posted by Samic View Post
    friend,after you get eeprom by VVDI PROG then load to VVDI2 can set 0 KM.or wait for VVDI PROG will add new 'script function'.
    When will this feature be implemented
  4. #2838
    Jan 2019
    if you read hte rules and ask in the correct place you will have more luck getting answers
    vvdi prog where to buy better on eBay or official website http://www.vvdishop.com/ and what's the difference?
    how much have I watched the same prices
  5. #2839
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Can anyone tell me what is the point of M35080/D80 Adapter!?? I have done at least 3xD80 and today 2xD160 eeproms and haven't had any issues with erasing first to lines (mileage) in memory. So..?
  6. #2840
    May 2016
    Quote Originally Posted by sniegavirs View Post
    its more for old 35080 s like 35080 3, 35080 6, v3, v6
  7. The Following 2 Users Say Thank You to Levanime For This Useful Post:
    bry0sb (29th January, 2019), sniegavirs (22nd January, 2019)
  8. #2841
    Nov 2018
    Quote Originally Posted by einet View Post
    Hello
    I become my new vvdi prog and have this problem on logI have
    12V Power Adaptor unconnected
    I have 12V onected! is this a problema or not ?
    I just noticed the same problem today. Reading a EWS3. Usng the same 12v conector (AC) I use for my VVDI-MB and it's worked fine. Today just saying 12v power not connected on 4.7.8
    I have another 12V connector that is from a usb to transformer to 12v connector that I don't like to use but tried it and it worked and it got the job closed. Weird though.
  9. #2842
    Jul 2018
    CHINA
    Quote Originally Posted by javyb View Post
    yes ,you can use vvdi 2 for that ,modify the mileage .
  10. #2843
    Quote Originally Posted by PerryZhang View Post
    I don't have vvdi2
  11. #2844
    pierre renault's Avatar
    Jan 2013
    Default VVDI PROG
    In VVDI PROG Why there is a option to change mileage to CAS 3.3 +, 4.4 + ???????????
  12. #2845
    Jul 2018
    CHINA
  13. #2846
    rob h's Avatar
    May 2011
    So the vvdiprog does not calculate mileage,
    For those that do not have vvdi2, you could post dumps here.
  14. #2847
    Jan 2013
    PerryZang
    WHO TOLD YOU IN VVDI2? I know perfectly well that vvdi2 has a calculator but I need to buy it !!!!!
  15. #2848
    VVDIprog is in first place just a chip programmer. For CAS4 you will find free calculators that show VIN and mileage. Just download it.
    https://www.digital-kaos.co.uk/forum...4-Mileage-Tool
  16. The Following 2 Users Say Thank You to exe123 For This Useful Post:
    javyb (22nd January, 2019), WinWoj (27th February, 2019)
  17. #2849
    Jan 2013
    Hi, I look for a calculator for CAS and EZS!
  18. #2850
    Apr 2015
    VVDI PROG latest software version V4.7.9 update
    v4.7.9 (2018-1-27)
    * This version DON't need update firmware
    + Add VVDI PROG USER MUNUAL 4.7.9 version in Doc folder
    + Add MBM29F400TC/BC-PF, MBM29F400TC/BC-PFTR, MBM29F400TC/BC-PFTN, MBM29F200TC/BC-PFTN, MBM29F200TC/BC-PFTR,
    MBM29F200TC/BC-PF, MBM29F800TA/BA-PFTR, MBM29F800TA/BA-PFTN, MBM29F800TA/BA-PF options in <1-EEPROM&FLASH>-><FUJITSU>
    + Add TC1793-CAN options in <2-MCU>-><INFINEON-TRICORE>
    + Add R5F64525JFD, R5F64525LFD, R5F64525KFD, R5F6452NJFD, R5F6452NLFD, R5F6452NKFD options in <2-MCU>-><RENESAS-R32C>
    + Add SPC5607B options in <2-MCU>-><ST-SPC560XXXX>
    + Add RATTAN-ZS options in <5-DASHBOARD>-><SAICMOTOR>
    + Add HYOSOW-S2-COMPUTER options in <8-OTHER>-><BAIC>
    + Add HYOSOW-S2-CCM options in <8-OTHER>-><BAIC>
    + Add A6L-C7-SUNROOF-MOTOR options in <8-OTHER>-><AUDI>
    Notes: please keep using the latest software version, any problem post here or PM technical support.
  19. The Following 9 Users Say Thank You to Samic For This Useful Post:
    BradyAus (27th January, 2019), damih (27th January, 2019), daxxer (27th January, 2019), habbyb (28th January, 2019), PocketHero (27th January, 2019), polys123 (27th January, 2019), sniegavirs (27th January, 2019), sqlkarol (28th January, 2019), ThiagoArgentino (28th January, 2019)
