Page 191 of 295 FirstFirst ... 91141181186187188189190191192193194195196201241291 ... LastLast
Results 2,851 to 2,865 of 4422
Thread: VVDI PROG
  1. #2851
    Apr 2013
    Vvdi prog 28fxxx
    And 29fxx
    Not writhe
    Enviado de meu SM-G935F usando o Tapatalk
  2. #2852
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by ravate View Post
    Vvdi prog 28fxxx
    And 29fxx
    Not writhe
    did you erase 29Fxxx before write ???
    many thanks to friend kevfield
  3. The Following User Says Thank You to daxxer For This Useful Post:
    kevfield (27th January, 2019)
  4. #2853
    Moderator
    PremierD's Avatar
    Jun 2009
  5. The Following User Says Thank You to PremierD For This Useful Post:
  6. #2854
    Top Poster rojhat's Avatar
    Sep 2015
    france
    Hi he correct reading cas2 mcu Reading ? All read inst.same . Simple xprog can do properly
    Envoyé de mon SM-A605FN en utilisant Tapatalk
  7. #2855
    alclot's Avatar
    Melee Island
    Hi mates,
    Question and sorry for my ignorace but with "Xhorse VVDI Prog M35080/D80 Adapter" can I erase the 35080 SOIC8 from opel astra h dash and program full or with normal socket I can?
    Thanks in advance
  8. #2856
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by alclot View Post
    Hi mates,
    Thanks in advance
    Yes you can
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  9. The Following User Says Thank You to CarCity For This Useful Post:
    alclot (29th January, 2019)
  10. #2857
    habbyb's Avatar
    Romania
    Xhorse team , please add to read motorola HC05 mask 0D62J is not in list .
  11. #2858
    EARTH
    vvdi prog worked well in frm3.
    Now he accuses error, Frequecia.
    Error of 2 ecu frm3, xprog 100% R / W.
    Does anyone have this problem?
    12v in =ok
    solved.
    Everything worked, I resounded DB25 connector
  12. #2859
    Quote Originally Posted by datapage View Post
    12v in =ok
    Check your mcu cable if the coax wire is fine. on mine one cable was broken after some use.
  13. #2860
    EARTH
    frm3 does not use coaxial cable only gnd vcc rst bkgd
  14. #2861
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    ABS MANDO-MGH60
    Read and write (D-Flash+P-Flash)
    OK
  15. The Following 10 Users Say Thank You to CarCity For This Useful Post:
    alclot (29th January, 2019), automotrizVIP (29th January, 2019), datapage (29th January, 2019), Ginocar (29th January, 2019), habbyb (30th January, 2019), Maartinj (29th January, 2019), PocketHero (29th January, 2019), polys123 (30th January, 2019), sniegavirs (29th January, 2019), WinWoj (27th February, 2019)
  16. #2862
    Oct 2016
    Minsk
    R5F61723 - Identification work, erase work, write error.
    Porshe & VAG EDC17/ MED17 clone, adaptation, immooff, change Power Class. BCM2 clone, ELV synchonisation, adaptation.
  17. The Following User Says Thank You to Medions For This Useful Post:
    taxo1965 (29th January, 2019)
  18. #2863
    Jan 2017
    hi all,
    i have a problem here, i cannot read 0l15y cas 3+, just goes trying and it doesnt read it, it does read ID tho.
    i have soldered the pins all clean and all good
    Need help please...
  19. #2864
    Apr 2016
    uk
    Quote Originally Posted by Everythiinng View Post
    hi all,
    Need help please...
    Post pictures..
    Never had problems to read that mask
  20. #2865
    Jan 2017
    Post pictures..
    Pictures? What pictures mate, im telling you with words. I connected the pins 3 times yesterday i cleaned them checkedd if any of them is not working everything was fine in soldering state. On VVDI PROG state it was not, it was trying to crack went up until 100% and nothing, when i read ID it could read it, if i tried to crack with other MCU it did and read pieces of it. So it was not in solder fault it was either in software or hardware of VVDI PROG. Any solution i would appriciate it
  21. The Following User Says Thank You to Everythiinng For This Useful Post:
    javyb (31st January, 2019)
