Page 199 of 283 FirstFirst ... 99149189194195196197198199200201202203204209249 ... LastLast
Results 2,971 to 2,985 of 4422
Thread: VVDI PROG
Hybrid View
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by camouflaged View Post
    Hi . I have read clusters eeprom and clear first two lines.. but how can i know on which position should i write the new milage? I mean shall I type the new milage on the beginning of the first row, or to the end of the 2nd row?
    can somebody modify the bin file to set milage to 91 000km? - i have masked the vin. thanks
    1st row
    16 37 16 37 16 37 16 37 16 37 16 37 16 37 16 37
    2nd row
    in future post dumps in dashboard section
  2. The Following 2 Users Say Thank You to teerak2uk For This Useful Post:
    camouflaged (22nd April, 2019), mickye_dj (22nd April, 2019)
  3. #2
    Jan 2019
    hi. thank you again. ok. i will. how did you calculate the new milage? thanks. In conversion 91000 dec > hex is 16378, why is it only in yours 16 37?
    lion0304's Avatar
    Oct 2014
    Default Pinout DACIA Duster Renault 985105129R with SPC560P50L3
    SRS DUSTER 2017
  5. The Following 15 Users Say Thank You to lion0304 For This Useful Post:
    alclot (13th May, 2019), amaflo (24th April, 2019), barho67 (22nd April, 2019), danielif (23rd April, 2019), galaxy0634 (22nd April, 2019), habbyb (22nd April, 2019), harciogu (24th April, 2019), hohoeho321 (1st January, 2024), laki23 (23rd April, 2019), nstnkt (29th September, 2021), Perryking (23rd April, 2019), PocketHero (22nd April, 2019), racin-snake (10th May, 2019), SALAS (27th July, 2019), ThiagoArgentino (24th April, 2019)
  6. #4
    Moderator
    PremierD's Avatar
    Jun 2009
    1637 > dec * 16 is the algo mate
  7. The Following 4 Users Say Thank You to PremierD For This Useful Post:
    camouflaged (23rd April, 2019), danielif (23rd April, 2019), daxxer (23rd April, 2019), PocketHero (23rd April, 2019)
  8. #5
    Jan 2019
    thats what i needed to know ! thank you so much !
  9. #6
    gtcricardo's Avatar
    Jan 2018
    Cr7
    Samic how can i update my vvdi prog if dont connect to your server !!!
    only 4.8.1 but every time i open soft cames the messenger to update to 4.8.3 but when i try dont conect to server...
    One for all and all for one!!!
  10. #7
    Oct 2018
    Quote Originally Posted by gtcricardo View Post
    Download new sw file. Replace old sw file with new. Use .exe from new file to launch sw. Never used online server to update. Only for frimware update.
  11. The Following User Says Thank You to BradyAus For This Useful Post:
    gtcricardo (24th April, 2019)
  12. #8
    gtcricardo's Avatar
    Jan 2018
    Cr7
    Can you please share 4.8.3 software link?
  13. #9
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Today i had to reset mileage and change VIN on F30 cluster. Inside it had 35160WT chip and i don't have vvdi prog adapter for it so simply did read it as D160 and i also had broken cluster with D160 chip so i wrote all memory from 35160 to D160, reset mileage and changed VIN and cluster works perfectly!
  14. #10
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by sniegavirs View Post
    and the Red Dot is NOT burning....?
  15. #11
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by figani View Post
    No. When i connected dash to car it took in mileage from car and VIN i already wrote in the memory. You think RED DOT should be on because of different chip!?
  16. #12
    Yes as the I'd in the original eeprom and the micro need to match otherwise red dot that's what I've been told
    Sent from my SM-N960F using Tapatalk
  17. #13
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by javyb View Post
    And if the dot is the problem what is the working option here? Buy VVDI Prog M35160WT adapter and erase the mileage, change VIN or to buy Xhorse 35160WD chip and use that!????
  18. #14
    ASCM's Avatar
    Oct 2018
    how did you changed vin does it have checksum?
  19. #15
    ASCM's Avatar
    Oct 2018
