Once i tried to change cluster on F25 and tried to change VIN without worrying about checksum and it worked without any problem. And since then i have done the same with F01 dash and F10 dash. Cars had no errors and dash was working perfectly so i went with the same option here on F30. After that i am doing coding with ESYS. Maybe ESYS does checksum in that EEP when coding the dash!?? Don't know exactly!
I know that both 35160WT chip almost works the same as D160. 35160WT just have better security on mileage part. So i was willing to try it.
But i still want to know witch is the best solution for this! Go with adapter (if it can erase mileage part...) or go with Xhorse 35160DW chip..?????
What you say is really impossible...whole vin doesn’t need checksum...one short vin needs...other short vin is part of coding and yes can be repaired with esys...also many dashes have vin in second eeprom which also needs checksum...other wise you have fault in diag, red dot and mileage mulfunction...
Professional BMW immo solutions
Macedonia is one and GREEK!!!
Who can tell partnumber this element ?
Porshe & VAG EDC17/ MED17 clone, adaptation, immooff, change Power Class. BCM2 clone, ELV synchonisation, adaptation.
I have try a lot of things...
Why your dash not show red dot, maybe someone before you soldered the red dot led out of display... I can't say nothing smart about it, really...
But fact is, you change Eeprom in dash... And the Ori 35160wt Eeprom ID is not longer in connection with KI... the red dot will shine... Like the sun is shining each morning, from the east...
bearheroes (28th April, 2019)
Medions (29th April, 2019)
VVDI PROG latest software version V4.8.2 update
v4.8.2 (2018-4-25)
* This version DON't need update firmware
+ Add VVDI PROG USER MUNUAL 4.8.2 version in Doc folder
+ Add R5F10C/D_Data_8KB_Read, R5F10C/D_Data_8KB_Write, R5F10C/10DxC_Flash_32KB_Read, R5F10C/10DxC_Flash_32KB_Write, R5F10C/10DxD_Flash_48KB_Read,
R5F10C/10DxD_Flash_48KB_Write, R5F10C/10DxE_Flash_64KB_Read, R5F10C/10DxE_Flash_64KB_Write, R5F10DxF_Flash_96KB_Read, R5F10DxF_Flash_96KB_Write,
R5F10DxG_Flash_128KB_Read, R5F10DxG_Flash_128KB_Write, R5F10DxJ_Flash_256KB_Read, R5F10DxJ_Flash_256KB_Write, R5F10DxK_Flash_384KB_Read,
R5F10DxK_Flash_384KB_Write, R5F10DxL_Flash_512KB_Read, R5F10DxL_Flash_512KB_Write, R5F10CxBx_Flash_24KB_Read,R5F10CxBx_Flash_24KB_Wri te,
options in <2-MCU>-><RENESAS-RL78-D1A>
+ Add R5F104XX_Data_4KB_Read, R5F104XX_Data_4KB_Write, R5F104XX_Data_8KB_Read, R5F104XX_Data_8KB_Write, R5F104xA_Flash_16KB_Read, R5F104xA_Flash_16KB_Write,
R5F104xC_Flash_32KB_Write, R5F104xC_Flash_32KB_Read, R5F104xD_Flash_48KB_Read, R5F104xD_Flash_48KB_Write, R5F104xE_Flash_64KB_Read, R5F104xE_Flash_64KB_Write,
R5F104xF_Flash_96KB_Read, R5F104xF_Flash_96KB_Write, R5F104xG_Flash_128KB_Write, R5F104xG_Flash_128KB_Read, R5F104xH_Flash_192KB_Read, R5F104xH_Flash_192KB_Write,
R5F104xJ_Flash_256KB_Read, R5F104xJ_Flash_256KB_Write, R5F104xK_Flash_384KB_Read, R5F104xK_Flash_384KB_Write, R5F104xL_Flash_512KB_Read, R5F104xL_Flash_512KB_Write,
options in <2-MCU>-><RENESAS-RL78-G14>
+ Add LAGUNA-UCT-BCM(2013) options in <4-IMMOBILIZER>-><RENAULT>
+ Add LACROSSE options in <4-IMMOBILIZER>-><GM>
+ Add EMGRAND-GL-PEPS(2017) options in <4-IMMOBILIZER>-><GEELY>
+ Add SWIFT options in <7-AIRBAG>-><SUZUKI>
+ Add BALENO options in <7-AIRBAG>-><SUZUKI>
+ Add NEW-REGAL-SAS(2009-2013) options in <7-AIRBAG>-><BUICK>
+ Add A6L-LEVEL-REGULATOR(2014) options in <8-OTHER>-><AUDI>
+ Add IX35-POWER-DISTRIBUTOR(2014) options in <8-OTHER>-><HYUNDAI>
+ Add 740-PLG-COMPUTER options in <8-OTHER>-><BMW>
+ Add NATURAL-GAS-CONGPUTER options in <8-OTHER>-><CHANGAN>
Notes: Please download the latest software version, any problem you can post here or PM technical support.
aem (29th April, 2019), barho67 (29th April, 2019), BradyAus (29th April, 2019), damih (29th April, 2019), Faraday (29th April, 2019), habbyb (30th April, 2019), hojo25 (29th April, 2019), keyantic (30th April, 2019), sniegavirs (29th April, 2019), ThiagoArgentino (30th April, 2019), weza247 (30th April, 2019)
