Why do I always get the message server error?
Hi for 35160wt change to 35160dw job need need 35160wt adapter? Thanks
Any luck to do Kia smart key remote SV1 XMFGEO3 with VVDI PROG. At least to read and write?
Sent from my SM-G930F using Tapatalk
vasa (3rd May, 2019)
There is no adapter anymore.
It must be installed other EEprom.
http://www.xhorsevvdi.com/wholesale/...w-adapter.html
In CAS4 there are 4 versions but I see they look exact the same so my question is: It's whether to me if I prefer to remove components or cut tracks?
it is up to you whether you prefer to cut lines or remove elements.
p1et (2nd May, 2019)
VVDI PROG 4.8.2 download link.txt
bad link
datapage (20th May, 2019)
Anyone faced problem with not reading eeproms in socket? Via clip adapter all good, but in socket not read. When measuring vss and vcc jumps about 2V on read, but always shows chip not connect or reads zeroes.
If post helped, allways hit thank's
Read KIA Sorento 2016 SMK and extract Password
Successes
I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
alclot (2nd June, 2019), barho67 (5th May, 2019), datapage (6th May, 2019), habbyb (6th May, 2019), PocketHero (5th May, 2019), racin-snake (10th May, 2019), taxo1965 (5th May, 2019), u.s (16th May, 2019)
Bcose the two pcb and the two inner pin rows difficult to acces to the eep
EEP = 95160
You must cut the red cross marked wires! (when you finished connect again)
