Page 207 of 295 FirstFirst ... 107157197202203204205206207208209210211212217257 ... LastLast
Results 3,091 to 3,105 of 4422
Thread: VVDI PROG
  1. #3091
    Feb 2017
    Madrid Spain
    Default vvdiprog repair
    I have a problem with my vvdiprog programmer causing a short circuit connecting an airbag unit and now my device does not turn on by usb only turn on when I put external 12v power it recognizes the pc but can not read any chip shows device error 10 can someone know how to fix this problem ? Thank you
  2. #3092
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by dashtool2016 View Post
    contact seller for repair/return procedure
  3. #3093
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by vasa View Post
    Use another programmer no need any cut wire. This is for me better work.... Or use witt VVDI ISP eeprom adapter. Work as professional...
    if not cut the wires the cpu will wake up..and blocking the SPI bus bcose the SPI protocolls only one master interface allowed and in this case the programmer MUST be the master not the CPU. You can halt the cpu thru the reset pin if you can reach it. On kline isn't possible. But the reset pin it is the same side like the eeprom
    The vvdi eeprom adapter working only if you phisically see and able to connect to the eeprom. But you can't bcose the it is on the pcb inner side. If you prefer to desolder or cut these pin rows and sockets on the picture is it's your call. I choose the cuttung. It's fast and safe
  4. The Following User Says Thank You to jodge For This Useful Post:
    p1et (7th May, 2019)
  5. #3094
    Quote Originally Posted by hojo25 View Post
    There is no adapter anymore.
    It must be installed other EEprom.
    http://www.xhorsevvdi.com/wholesale/...w-adapter.html
    Yes, but how do you program 35160DW? What do you select in vvdiprog?
  6. #3095
    Usa
    Quote Originally Posted by nemena View Post
    I choose this one.
  7. The Following User Says Thank You to hojo25 For This Useful Post:
    nemena (9th May, 2019)
  8. #3096
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    In this thread you`ll find it...
    but here again...
    When I help you press Thanks and Reputation...
  9. The Following 4 Users Say Thank You to figani For This Useful Post:
    crazylou2017 (13th June, 2019), nemena (9th May, 2019), publiperro (27th February, 2023), zecas (16th May, 2019)
  10. #3097
    ibratex's Avatar
    Jul 2015
    angola
    help me !!!!!!!!!!!!!!!!
    today my vvdiprog fell on the ground my worker didnt pay atention now i plug into usb the drivers in device manager are good but always say device error check usb driver
    i had installed on both laptops same problem so i dissasembled the device found out that the battery 3v inside was lose negative i soldered again but its the same what should i do ????
  11. #3098
    Quote Originally Posted by ibratex View Post
    If battery was removed, security data is gone. You need to send in for repair.
    There is nothing you can do on your own.
  12. #3099
    Thank you!
    It worked fine on a bmw bike from 2018.
  13. The Following 2 Users Say Thank You to nemena For This Useful Post:
    habbyb (10th May, 2019), javyb (9th May, 2019)
  14. #3100
    ibratex's Avatar
    Jul 2015
    angola
    ok thanks !!!... maybe they should do more secured way to us before securing their mcu ..nothing perfect
  15. #3101
    jodge's Avatar
    Mar 2017
    yeah this Dallas based secu is literally garbage when your customers far away from you. If the backup battery is depleted or removed like your no way to fix BTW SMOK using the same s.hit
    There is plenty of same level security stuffs, without battery or simillar things i mean bulletproof stuffs
  16. #3102
    ASCM's Avatar
    Oct 2018
    hello does anyone know the steps to read THE DATA {DFLASH PFLASH EEPROM AND POF}RFA RANGE ROVER
    DO I NEED TO CLICK RESET SIGURITE BEFORE READING ?
  17. #3103
    rob h's Avatar
    May 2011
    1.Use "Reset Sec"unlock chip, the original security byte displayed in the window below
    2.Read/write D-FLASH, EEE, P-FLASH and POF data, the command can be executed many times
    3.Use "Set Sec", input the security byte read from step 1
    There are non secured, and secured.
  18. #3104
    ASCM's Avatar
    Oct 2018
    i think for only for writing its need to click reset sigurite not for backup
  19. #3105
    Nov 2011
    Macedonia
    Default Upa Connection without cut track
    Quote Originally Posted by jodge View Post
    Bcose the two pcb and the two inner pin rows difficult to acces to the eep
    EEP = 95160
    You must cut the red cross marked wires! (when you finished connect again)
    Its to difficult with vvdi connection....use upa
    Baze007
