Page 21 of 295 FirstFirst ... 1116171819202122232425263171121 ... LastLast
Results 301 to 315 of 4422
Thread: VVDI PROG
  1. #301
    Oct 2015
    I cannot upgrade my VVDI-Prog, when I connect, it is red Dot and yellow flashing. When I go to upgrade, then it's only red light...and cannot find device.
  2. #302
    Apr 2015
    Quote Originally Posted by thebigk View Post
    mate,currently the latest version is V4.3.1 version.not need to update the firmware.usually download the latest version then use directly.
    if new version need to update firmware the update log will show you.please contact me on skype.i will check and help you.
  3. The Following User Says Thank You to Samic For This Useful Post:
    keyantic (28th January, 2016)
  4. #303
    Apr 2015
    VVDI PROG latest version V4.3.1 update
    v4.3.1 (2016-01-27)
    * This version DON't need update firmware
    + Add MC9S12GN16_UNSECURED,MC9S12GNA16_UNSECURED,
    MC9S12GN32_UNSECURED,MC9S12GNA32_UNSECURED,
    MC9S12G48_UNSECURED,MC9S12GA48_UNSECURED,
    MC9S12GN48_UNSECURED,MC9S12G64_UNSECURED,
    MC9S12GA64_UNSECURED,MC9S12G96_UNSECURED,
    MC9S12GA96_UNSECURED,MC9S12G128_UNSECURED,
    MC9S12GA128_UNSECURED,MC9S12G192_UNSECURED,
    MC9S12GA192_UNSECURED,MC9S12G240_UNSECURED,
    MC9S12GA240_UNSECURED optionsMask (0N95B,0N51A,0N75C,1N75C,0N48A,1N48A)
    MC9S12HA32_UNSECURED,MC9S12HA48_UNSECURED,
    MC9S12HA64_UNSECURED,MC9S12HY32_UNSECURED,
    MC9S12HY48_UNSECURED,MC9S12HY64_UNSECURED optionsMask (0M34S)
    MC9S12P32_UNSECURED,MC9S12P64_UNSECURED,
    MC9S12P96_UNSECURED,MC9S12P128_UNSECURED options Mask (0M01N)
    MC9S12XEA128_UNSECURED,MC9S12XEG128_UNSECURED,
    MC9S12XEA128_SECURED,MC9S12XEG128_SECURED options Mask (1M53J,2M53J,0N36H,1N36H)
    MC9S12XHY128_UNSECURED,MC9S12XHY256_UNSECURED optionsMask (0M23Y)
    MC9S12XS64_UNSECURED,MC9S12XS128_UNSECURED,
    MC9S12XS256_UNSECURED options Mask(0M04M,1M04M,0M05M)in <2-MCU>-><MOTOROLA>
    + Add MC9S12XE_UNLOCK option in <2-MCU>-><MOTOROLA>(Backup all data before use it)
    + Add ME20U2-XET256-BACKUP,ME20U2-XET512-BACKUP,MT22-XEP768-BACKUP,
    MT60-XEP768-BACKUP options in <3-ECU>-><DELPHI>
    + Add the 12V power adaptor status in information dialog
  5. The Following 5 Users Say Thank You to Samic For This Useful Post:
    ahl (28th January, 2016), diagprog7 (28th January, 2016), filutek (30th January, 2016), Key Center (28th January, 2016), keyantic (28th January, 2016)
  6. #304
    Apr 2015
    Notes:Because of Chinese Traditional Spring Festival,mostly company will have a vacation from 3rd-13th,February,2016 in china.
    in this period worker all not in company,about repair device or other issues should be waiting for the vacation end.
    if User have any problem can post here,after back we will check and solve as soon as possible.
  7. The Following 3 Users Say Thank You to Samic For This Useful Post:
    ahl (28th January, 2016), keyantic (28th January, 2016), Maartinj (28th January, 2016)
  8. #305
    bearheroes's Avatar
    Dec 2011
    Still no update for pcf7945 bmw 868 keys...
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  9. The Following User Says Thank You to bearheroes For This Useful Post:
    totalkey (29th January, 2016)
  10. #306
    Oct 2015
    I have connection with VVDI Prog...but it fails to update repeatedly. Any ideas? It hangs up during the "connecting to server" phase.
    Also I am trying to read CAS 2 - and repeatedly fails to crack. Has anyone read this successfully with VVDI Prog?
  11. #307
    Apr 2015
    friend,V4.3.1version DON't need update firmware.please download the latest version use it directly.
    About CAS2 there are 2 types,please check and confirm choose the right connection diagram.
  12. #308
    Oct 2015
    VVdi doesn't want to be defined in the program
    on win10
    on win xp everything is good
  13. #309
    I've connected the in-circuit cable to a 868 BMW key board which looks exactly the same as in the VVDI software picture. I've checked the connections a few times and they are fine.
    I've also checked de pcf79xx adaptor and it's the latest version, with a 0 ohm in R19 resistor.
    My OS is windows 7 and I've selected PCF7945 - IN CIRCUIT option in the VVDI software.
    When I try to read the eeprom I always get the same error:
    - Read (0%)
    - Read error
    I've tryed a few times with and without the soldered battery of the keyfob.
    Do you have any suggestions? Someone have readed the eeprom correctly?
    Thanks in advance!
  14. #310
    bearheroes's Avatar
    Dec 2011
    you won't be able to read it.Only option to read it is reset security and read it.
    But this will erase content.
  15. The Following User Says Thank You to bearheroes For This Useful Post:
    mickye_dj (19th October, 2017)
  16. #311
    Thank you bearheroes,
    Yes, when I reset the security I can read it. But when VVDI renew the mcu, it also protects its contents and that's why I can't read the Eeprom.
  17. #312
    Oct 2015
    I bought a new vvdi-prog
    and I have the exact same problem
    the software can not find device
  18. #313
    rob h's Avatar
    May 2011
    What os are you running on?
    Did you run as admin?
    Virus scanner off?
    Did you allow unsigned drivers?
    Quote Originally Posted by gigitalfvdi View Post
  19. #314
    Oct 2015
    Quote Originally Posted by rob h View Post
    Virus scanner off?
    win10 64
    yes admin
    scanner off
    driver allow
    winxp work ok
  20. #315
    Is this tool safe for cash 5m48h? Or is it very risky
