Page 210 of 290 FirstFirst ... 110160200205206207208209210211212213214215220260 ... LastLast
Results 3,136 to 3,150 of 4346
Thread: VVDI PROG
  1. #3136
    Oct 2017
    Quote Originally Posted by centralmultimarcas2016 View Post
    last update ... device error please check usb driver ... already made everything else windows pc outo cable install driver and nothing ever this error
    You have to send back to the supplier. Unfortunately you can't fix it. I had same problem. At the end I sent it back under warranty and they replaced an IC on the board.
  2. #3137
    didi_du_93000's Avatar
    France Paris
    Any one know if we can renew remote key psa with PCF7945A / HITAG 2.
    It's used on picasso, 308 II...
    Any virgin file?
    Also I need the same remote shape with PCF7953 / HITAG AES
    it's used on 3008 II, C3 III...
    With Tapatalk
  3. #3138
    Apr 2016
    vvdi prog can not even read 35160 with clip adapter?
  4. #3139
    Apr 2016
    uk
    Quote Originally Posted by didi_du_93000 View Post
    Any virgin file?
    With Tapatalk
    I think both are supported by kd-x2.
  5. #3140
    France Paris
    I have only Vvdi prog at this time.
    With Tapatalk
  6. #3141
    Nov 2010
    hi, airbag toyota 89170-0D590 RENESAS R5F61725
    trying, read id receives an error
    try frequency failed
    maybe someone has a good pinout
  7. #3142
    Oct 2017
    Turkey
    Hi all
    i use 4.8.3 software, device firmware is 2.0.0 when i try to update the firmware it never gets the link. How can i update firmware manually ?
  8. #3143
    Apr 2016
    uk
    Does anyone have pinout for E39 dash?
  9. #3144
    Oct 2016
    France
    https://cloud.mail.ru/public/v9nk/2kK9PECCp
  10. The Following User Says Thank You to barho67 For This Useful Post:
    comizelu (16th June, 2019)
  11. #3145
    Sep 2016
    hi freind price pls
  12. #3146
    wissamshaat's Avatar
    Oct 2017
    france
    any one have problem writing 95080 eeproms?
    reading ok writing no ok
    any fix for this
    thank you
  13. The Following User Says Thank You to wissamshaat For This Useful Post:
    comizelu (19th June, 2019)
  14. #3147
    Did you erase it first?
  15. #3148
    Apr 2016
    uk
    Quote Originally Posted by wissamshaat View Post
    any fix for this
    thank you
    I had problems with 95xxx eeproms.could not read/write well.
    I solve the problem with changing the eeprom soldering plate..
  16. #3149
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by jodge View Post
    Bcose the two pcb and the two inner pin rows difficult to acces to the eep
    EEP = 95160
    You must cut the red cross marked wires! (when you finished connect again)
    https://www.digital-kaos.co.uk/forum...=1#post3568591
    Anyone tried this solution by setting voltage to 3.3V and without cutting any tracks? Everywhere I see users say that with UPA it's safe to read with 3.3V so I think shouldn't be a problem with vvdi or xprog with those setting?
  17. #3150
    Apr 2009
    RS, BRASIL
    lets go scripting with vvdiprog
  18. The Following 7 Users Say Thank You to valdirld For This Useful Post:
    automotrizVIP (25th June, 2019), datapage (29th June, 2019), milehighlockdoc (25th June, 2019), Mingaz (27th June, 2019), rola1971 (11th July, 2019), sniegavirs (22nd June, 2019), zalimhan74 (30th March, 2024)
