Page 216 of 290 FirstFirst ... 116166206211212213214215216217218219220221226266 ... LastLast
Results 3,226 to 3,240 of 4348
Thread: VVDI PROG
  1. #3226
    Sep 2015
    Botswana
    hie all
    i have a problem with my device it cant be detected by the pc what could be the problem l
    i have checked the usb port and it looks fine
    thanks in advance
  2. #3227
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by LEORNARD NKATA View Post
    hie all
    thanks in advance
    check with other PC, make sure no driver issue
    if still "faulty" contact your seller to help you return to manufacture
  3. The Following User Says Thank You to Maartinj For This Useful Post:
    LEORNARD NKATA (13th August, 2019)
  4. #3228
    Nov 2015
    I have a problem with reading D70F3506
    I checked all possibilities several times
    receives a message - try frequency failed
    vvdi 4.8.5
  5. #3229
    hivrich's Avatar
    Sep 2012
    Ukraine
    Quote Originally Posted by xjojo View Post
    vvdi 4.8.5
    Look at the quartz near D70F3506
  6. #3230
    Nov 2015
    I have a problem finding him.
    is it not possible?
    And what are you going to ask about quartz?
  7. #3231
    hivrich's Avatar
    Sep 2012
    Ukraine
    is it not possible?
    100pin - 14,15pins quartz
    144pin - 23,24pins quartz
    see connection instructions
  8. #3232
    Nov 2015
    ok
    144 - quartz - I found
    will you tell me what to do?
    remove? bypassed ?
  9. #3233
    hivrich's Avatar
    Sep 2012
    Ukraine
    ok
    remove? bypassed ?
    I think to see the frequency of quartz and set it in the programmer
  10. #3234
    Nov 2015
    my knowledge on this subject may be poor
    the quartz mark is 0162k or D162k - hardly visible.
    possibly, how can I measure it?
  11. #3235
    Aug 2010
    Polska
    On Vvdi prog, i have a ecu Vespa gts , mcu stm8s207cb inside , when i press read eeprom, flash whatever , read some 00 00 00
    Regards Michal
    no links to members sites in sigs
  12. #3236
    ibratex's Avatar
    Jul 2015
    angola
    Quote Originally Posted by CarCity View Post
    Delphi MT86 (3500) Gearbox
    Hyundai - Kia
    -Read and write ok by ECU reflash cable
    -Pinout some as VVDI-Prog manual
    -Other operation some as picture
    ( The power should be disconnect and connect before each operation )
    hello how are you , all freinds , i am trying to clone mt86 with 2 infinion inside , i tried to read with vvdi prog the old ecu it says chip not connected i did exactly as the help in vvdiprog
    what am i doing wrong , the old ecu have only 3 coils working i dont know what component is for the coils so i decided clone on other one
    car start with old ecu , and also i tried to read with combiloader it read flash normally i copied on donor ecu but car didnt start so i want to copy whole flash and eeprom with vvdiprog but always chip not connected ,
    anyone have or had same problem ?... please maybe helping with showing me with coils responsible component also helps alot , thanks in advance
  13. #3237
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by ibratex View Post
    My friend
    In the Delphi MT86 you have 2 Tricor _ TC1766 ( Motor + Gear box )
    To read TC1766 motor you should use this method :
    Raise PIN 122
  14. #3238
    ibratex's Avatar
    Jul 2015
    angola
    i should not lift any pin ?
  15. #3239
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    PIN 122 should be lift
  16. #3240
    ibratex's Avatar
    Jul 2015
    angola
    i lifted and tried 2 ecus same problem i dont know what is wrong . i changed resistors also its 0.995 kohm = 1000 ohm (Brown, Black, Red, Gold ) color code each and the obd conections are clear but not reading . tried combiloader read ok but only map area i need full , waht would be wrong :S
