Page 219 of 295 FirstFirst ... 119169209214215216217218219220221222223224229269 ... LastLast
Results 3,271 to 3,285 of 4422
Thread: VVDI PROG
  1. #3271
    Bosch adapter tested with bmw ecu and did not have success
    [2019-09-14 18:24:08] : Communicating... 94%100
    [2019-09-14 18:24:12] : Communicating... 100%100
    [2019-09-14 18:24:30] : 7 Chip enter failed
  2. The Following User Says Thank You to phatty123 For This Useful Post:
    p1et (16th September, 2019)
  3. #3272
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by phatty123 View Post
    can you post label of ecu ?
    many thanks to friend kevfield
  4. #3273
    Quote Originally Posted by daxxer View Post
    dont have ecu close by but I have part # in notepad
    0261s06727
    7619981
    Different part # 0261s10196 from F10 n55 I was able to read dflash with adapter, but did not give ISN like it does in boot mode. I found ISN in dump. Reading pflash failed
  5. #3274
    Jun 2016
    Quote Originally Posted by p1et View Post
    Clone Xprog also great for HC05, I read many HC05 with 5.0 clone and always work.
    What about Xprog 5.8.4?
  6. #3275
    ghostrider72's Avatar
    Jul 2012
    UK
    There is a bug in 4.85. Wont read EWS4 with adapter. Says chip not connected. But it works fine in 4.80
  7. #3276
    p1et's Avatar
    Oct 2013
    I have W203 EIS with HC08 8H62A mask MCU and I see something like this for the 1st time. This mask is not specified in vvdi software so can VVDI Prog read this under different mask 1J35D / 2J74Y ?
    EDIT: I tried read as 1J35D and everything good.
  8. The Following 2 Users Say Thank You to p1et For This Useful Post:
    danielif (18th September, 2019), Weasel3 (16th September, 2019)
  9. #3277
    Jun 2013
    I have W203 EIS with HC08 8H62A mask MCU. Can VVDI Prog read this under different mask 1J35D / 2J74Y ?
    So HC08 would work with 1J35D with W203
    with W639 would be the same I guess?
    ST12 W639 there is no option in the menu. So it is try and test between 5 options. Anyone have experience?
  10. #3278
    p1et's Avatar
    Oct 2013
    FOr W639 ST12 there is menu VITO(VIANO) ST12
  11. The Following User Says Thank You to p1et For This Useful Post:
  12. #3279
    toutougsmserver's Avatar
    Jan 2013
    inside map
    I try read CEM range rover sport with mcu mc9s12xep768
    And get partittion information error must choose manualy
    When i choose manualy i can read dflash but eeprom is empty
    Is this mcu has only dflash no eeprom or vvdiprog have problem with kind of mcu ?
    VAG Bcm2,pcr2.1,edc17,med17,MED9.1.1 immo clone & data transfert
    PSA sid208 immo clone,synchro to bsi
    RB4,RB8 DEF FIX
    ODIS-S and E full install via remote
  13. #3280
    Oct 2016
    France
    try today to read 93lc66 from toyota rav4 immobox,reading 5 times and 5 times dump was bad,i try sixth time and dump was ok,for write the same 2-3 times not ok and 4th ok,with carprog read first time ok!
  14. #3281
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by barho67 View Post
    Bad with clip Adapter....?
    Or bad reading by soldering...?
  15. #3282
    Oct 2016
    France
    Quote Originally Posted by figani View Post
    with clip adapter was not ok and after was ok,i didnt solder it.. its dip8 i think
  16. #3283
    p1et's Avatar
    Oct 2013
    If you read in socket then well, it is what it is, you might get different readings. If you solder then you 100% sure it's not bad connection issue, that's why I always solder.
  17. #3284
    figani's Avatar
    Feb 2018
    solder down this black clip adapter and use Pomona. and youŽll see difference...
    but in any case, with clip the chances to corrupt data are very high...
  18. #3285
    Oct 2016
    France
    i solder 90% usually eeproms,but this one is 93lc66 in DIP8,so how can i solder it and where?)
