Page 221 of 295 FirstFirst ... 121171211216217218219220221222223224225226231271 ... LastLast
Results 3,301 to 3,315 of 4422
Thread: VVDI PROG
  1. #3301
    alclot's Avatar
    Melee Island
    v4.8.7 (2019-9-19)
    * This version DON't need update firmware
    * Fix BOSH ECU ADAPTER READ BUGs
    + Add VVDI PROG USER MUNUAL 4.8.7 version in Doc folder
    + Add R7F701062, R7F701064 ,R7F701067 options in <2-MCU>->
    + Add SCENIC(2007) options in<4-IMMOBILIZER>->
    + Add E3 options in<5-DASHBOARD>->
    + Add TIGGO5(2014) options in<5-DASHBOARD>->
    + Add 300(2005) options in<5-DASHBOARD>->
    + Add SOUTHEAST-DX3(2016) options in<5-DASHBOARD>->
    + Add FRM-SRS options in<8-OTHER>->
    https://mega.nz/#!itZURCbQ!8GoEieiNP...WcAgcMvhl5HQM8
    Password:123456]
    Done, Thanks
  2. The Following 7 Users Say Thank You to alclot For This Useful Post:
    amor89 (30th October, 2019), barho67 (18th October, 2019), habbyb (3rd October, 2019), hivrich (3rd October, 2019), jaelgti (2nd October, 2019), keyantic (23rd October, 2019), PocketHero (5th October, 2019)
  3. #3302
    Apr 2016
    someone had issue, what vvdi prog stop reading motorola processors (tried cas4, cas3, cas2)? eeprom read ok, tried to repair firmware, but always getting server connection error
  4. #3303
    Feb 2013
    UK Bristol
    Hi There.
    Have some one else schemat.. pinout of BOSH ECU ADAPTER cable, for AVDI PROG, which was released newly.
    My post helps you? Please Hit Buttons
  5. #3304
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by pocinas View Post
    Hi There.
    you meand for VVDI Prog...?
    when yes, as I see it not support N57/your car (until now)...
  6. #3305
    Feb 2013
    UK Bristol
    Yes for vvdi prog. They i see was some.realase but in my opinion is not worth for me spend £85 for cable which i can build self much cheaper (if is not some pcb with parts on DB25 Case..
  7. #3306
    It's not a simple cable. Some more electronics is involved to enable Bosch TSW mode. So forget to build it on your own
  8. #3307
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by exe123 View Post
    yes, forget to build your own cable
    anyway in the price of cable are online calculation of the ISN...
    its not only about few wires and that everything...
    many thanks to friend kevfield
  9. The Following User Says Thank You to daxxer For This Useful Post:
    habbyb (9th October, 2019)
  10. #3308
    ibratex's Avatar
    Jul 2015
    angola
    hello how are you , here i am trying to read bcm from chevrolet sonic
    BCM CONTINENTAL:
    • MCU NEC(RENESAS) D70F3469 + EEPROM 25160
    i managed to do pinouts and detected id C437B046B334B6B9
    but its encrypted , as i did search md flasher can do it ,, so please an update would be great for us and vvdiprog name
    thanks alot
  11. #3309
    solitaire's Avatar
    LT, jonava
    If NEC is locked, you can’t read it. Just obd solution
    http://ioterminal.com/?page_id=1098
  12. The Following User Says Thank You to solitaire For This Useful Post:
    mickye_dj (10th November, 2019)
  13. #3310
    jodge's Avatar
    Mar 2017
    Nissan Airbag module pinout Bosch 0285001318 Nissan 98820 5M302
  14. The Following 5 Users Say Thank You to jodge For This Useful Post:
    alclot (24th October, 2019), CarCity (22nd October, 2019), Perryking (23rd October, 2019), PocketHero (29th October, 2019), rob h (31st October, 2019)
  15. #3311
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Can anyone explain what is this meant for?
    http://www.vvdishop.com/wholesale/bm...n-adapter.html
    Is it for no-desolder read/write on FEM/BDC units?
  16. #3312
    Moderator
    PremierD's Avatar
    Jun 2009
    Yes......................
  17. The Following User Says Thank You to PremierD For This Useful Post:
    sniegavirs (29th October, 2019)
  18. #3313
    Feb 2013
    UK Bristol
    Quote Originally Posted by daxxer View Post
    Yes you have right my Friend.
    I ordered one cable of this, and just arrived and i can confirmed, there is 2 chip, few maybe transistors, diodes, resistors and capacitors.. Is not worth to build own for this money.
    ''anyway in the price of cable are online calculation of the ISN'' how i can activate this function on my VVDI prog? then
  19. #3314
    figani's Avatar
    Feb 2018
    I thought not neccessary to activate anything, maybe I´m wrong (?)...
    read ecu with internet online...
    offline not possible...
  20. #3315
    hivrich's Avatar
    Sep 2012
    Ukraine
    Hey.
    The program stopped starting (4.8.7 and 4.8.6). Windows 7
    Mistake:
    Running the program is impossible due to lack of NetClient.dll
    There may be information on how to fix this problem.
    thank
