Hi there lads. Dont sure which version software you use but on 4.8.8 maybe is some bugs. Yesterday i tried renew remote key for Opel Corsa D equipped on PCF7961 and write file is error with version 4.8.8.. with 4.8.7 all fine without any issue. So i recomended you maybe try diffrent version program.
My post helps you? Please HitButtons
anyone else had the new versions of vvdi prog get exe file deleted windows defender, it was fine until a recent update from microsoft
Hi mates,
Can anyone help reading 70F3380 on this sam from mercedes W204?
thanks a lot![]()
Meat-Head (9th December, 2019)
Solved problem.............
No need to remove that
Need to remove if cannot crack without removing. Manual clearly say that. Me and my friend tested 5m48h and didn't work without all component in place but worked after desoldering 1 resistor.
drpeter (9th December, 2019)
Hi friends
I have a problem with : MAC7242VAF64 in KIA Sorento Airbag unit ..
Wiring some as VVDI-Prog user manual ( I didn't understand where the 12V written on the map should be connected ??)
Read : OK
Erase+Unlock : OK
Write : OK
Verify : NOT OK
I try by any version but result some , dump verify is different , I appendix log file
Thanked for any help
I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
CarCity (15th December, 2019)
Solved ...
For write new file no need Erase + Unlock only load dump and write so verify success
