Page 225 of 295 FirstFirst ... 125175215220221222223224225226227228229230235275 ... LastLast
Results 3,361 to 3,375 of 4422
Thread: VVDI PROG
  1. #3361
    klonone's Avatar
    hi,, please down voltage, 4.5v , ,read ok all
  2. #3362
    klonone's Avatar
    Quote Originally Posted by louis21 View Post
    98% then Chip crack failure?upload the picture.connect 12V power?
    down voltaje vcc, 4.5v work well . regards
  3. #3363
    Feb 2013
    Hello all.Guys have anyone read this type of block?
    BOSCH ME7 MG350 2012
  4. #3364
    when will you add read/write Renesas RH850 R7F701414 ?
  5. #3365
    Nov 2019
    Kemerovo, RU
    hi!
    6fr920860b hw02 sw0104
    i need help... thz!
  6. #3366
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    VVDI PROG latest software version V4.8.9 update
    v4.8.9 (2019-12-21)
    * This version DON't need update
    firmware
    + Add VVDI PROG USER MUNUAL 4.8.9
    version in Doc folder
    + Add HYOSOW-S7 in
    <4-IMMOBILIZER>-><BAICMOTOR>
    + Add 820 in
    <4-IMMOBILIZER>-><LIFAN>
    + Add S5 options
    in<5-DASHBOARD>-><HAIMA>
    + Add CROSS options
    in<7-AIRBAG>-><SUZUKI>
    + Add AUDI-Q5-AMP options
    in<8-OTHER>-><AUDI>
    + Add 205-LAMP-RH options
    in<8-OTHER>-><BENZ>
    + Add 330-CABRIOLET-MODULE options
    in<8-OTHER>-><BMW>
    + Add F18-FZD options
    in<8-OTHER>-><BMW>
    + Add MED17.7.2(ADAPTER) options in
    <10-BOSH-ECU-ADAPTER>-><BENZ>
    + Add EDC17.7.2(ADAPTER) options in
    + Add EDC17.7.8(ADAPTER) options in
    + Add EDC17CP46(ADAPTER) options in
    + Add EDC17C45(ADAPTER) options in
    <10-BOSH-ECU-ADAPTER>-><BMW>
    + Add EDC17C56(ADAPTER) options in
    + Add EDC17C50_Fxx(ADAPTER)options in
    + Add MED17.3.5(ADAPTER) options in
    <10-BOSH-ECU-ADAPTER>-><FIAT>
    + Add MED17.9.30(ADAPTER) options in
    <10-BOSH-ECU-ADAPTER>-><KIA>
    + Add EDC17CP50(ADAPTER) options in
    <10-BOSH-ECU-ADAPTER>-><HONDA>
    + Add MED17.8.3(ADAPTER) options in
    <10-BOSH-ECU-ADAPTER>-><LANDROVER>
    + Add MEVD17.4.4(ADAPTER) options in
    <10-BOSH-ECU-ADAPTER>-><PEUGEOT>
    + Add ME17.1.6(ADAPTER) options in
    <10-BOSH-ECU-ADAPTER>-><VOLKSWAGEN>
    download link:
    https://mega.nz/#!f9QWgCRS!n9syZDOO7...1aX_R0wwnp4aBA
    many thanks to friend kevfield
  7. The Following 11 Users Say Thank You to daxxer For This Useful Post:
    DJenka (24th December, 2019), habbyb (23rd December, 2019), jaelgti (21st December, 2019), keyantic (22nd December, 2019), mickye_dj (2nd January, 2020), musti418 (4th January, 2020), PocketHero (22nd December, 2019), polys123 (27th December, 2019), sqlkarol (31st December, 2019), taxo1965 (22nd December, 2019), TeL200 (22nd December, 2019)
  8. #3367
    Lets see if they got the MED17.5 running now - new version, new chance
  9. #3368
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by chrisi1909 View Post
    can try ;-)
    with each new VVDI Prog update are added more supported ECU with new Bosch ECU cable adapter
    who not have it yet....easy PM me
  10. #3369
    The Adapter doesnīt support the 17.5 yet - so just Cables and Bootpin.But no connect with the 4.8.8.
    *EDIT*
    Nope, not finding the Security Bytes for this TC1766 - ID : 008B0000 in the 4.8.9 either...
  11. #3370
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    *EDIT*
    thats in VVDI Prog two different cables....ECU reflash cable adapter(standard) and BOSCH ECU cable adapter(optional)...
    when some ECU not supported yet, then be patient, will be sure added in future
  12. #3371
    Yeah i know, but as there is no Option for this ECU with the Bosch-Adapter Cable so far, we are trying it with the Standard Reflash Cable.
    Connects, identifys, trys about 15-20 Security Byte Codes and then ends with not Reading because it canīt get in.
  13. #3372
    Capture1.JPGis there any explanation for netclient.dll, is it virus or not???
    thanks in advance and best regards to all!!!
  14. #3373
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    when not support in BOSCH ECU adapter, then not work....no need to test it with standard ecu cable....
  15. #3374
    hivrich's Avatar
    Sep 2012
    Ukraine
    Quote Originally Posted by laki23 View Post
    Go into the settings.
    Excluded Files and Location.
    Indicate the path to the newly unzipped VVDIProg4.8.9.exe
    To add a file.
    Save changes.
  16. The Following User Says Thank You to hivrich For This Useful Post:
    laki23 (25th December, 2019)
  17. #3375
    Dec 2019
    Japan
    Hey,I have the link and picture of this product. If you have time, you can check it out. Link:http://www.eobdtool.co.uk/wholesale/...rogrammer.html
