Page 230 of 290 FirstFirst ... 130180220225226227228229230231232233234235240280 ... LastLast
Results 3,436 to 3,450 of 4348
Thread: VVDI PROG
  1. #3436
    Top Poster kristikapa's Avatar
    Quote Originally Posted by einet View Post
    Hello
    How i can read this micro with vvdi
    R7F7010183
    Did you manage to read it?
  2. #3437
    einet's Avatar
    hello
    No.
    Only CPT, but i also need ISP and license.
    I give ECU back to cliente.
  3. #3438
    For me it worked using connection in the picture I attached. Need to set voltage to 3.3V
  4. #3439
    Nov 2015
    Someone tested with NEC d70f3426? (Instrument cluster from passat)
  5. #3440
    Quote Originally Posted by Adam871 View Post
    All 70F3426 in Continental instrument cluster are locked.
    You cannot read it. Only erase is possible.
  6. The Following User Says Thank You to exe123 For This Useful Post:
    musti418 (17th February, 2020)
  7. #3441
    Aug 2016
    how can i read with VVDI PROG over the BDM function a ST "58BW016"?
    i find only EEPROM&FLASH / ST / M58BW016 and this is over the Adapter, not over BDM.
  8. #3442
    Oct 2017
    Quote Originally Posted by mantaNIkta View Post
    Check solderin? Using clamsheel dapter?
    soldering is good I checked pin by pin to make sure there was conecto y ever there was supposed to be and no connection where there wasn't supposed to be. i tried it with an mcu of the same family with mask id 0D69J it read it no problem. vvdi prog doesn't give me an option for the mcu I started above the 0D53J but they should be the same. could I have damaged the mcu by applying too much heat? what could be the issue. any help is appreciated thanks.
    Sent from my SM-N950U using Tapatalk
  9. #3443
    Jan 2014
    Anyone managed to read 70F3469 WITH vvdi-prog?
  10. #3444
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by esx503 View Post
    VVDI prog is not the best for HC05, sometimes there might be a problem with reading. Try xprog if you have, work 100%
  11. The Following User Says Thank You to p1et For This Useful Post:
    esx503 (25th February, 2020)
  12. #3445
    Top Poster antonnio_stef's Avatar
    romania
    Hi all
    is anyone who managed to read 70F3380 with VVDI PROG? today I tried all kinds of evidence and it does not read, it gives me Try Frequency failed
    & - sau WWW.DIAGNOZASECTOR5.RO
  13. The Following 2 Users Say Thank You to antonnio_stef For This Useful Post:
    esx503 (25th February, 2020), paulis (25th February, 2020)
  14. #3446
    ghostrider72's Avatar
    Jul 2012
    UK
    Same here with 70F3426
  15. The Following User Says Thank You to ghostrider72 For This Useful Post:
  16. #3447
    romania
    Now i try with smok jtag, I have same problem : no read this mcu renesas
  17. The Following User Says Thank You to antonnio_stef For This Useful Post:
  18. #3448
    70F3426 vag are locked mcu
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
  19. The Following User Says Thank You to koyot For This Useful Post:
  20. #3449
    kautuvera's Avatar
    https://mega.nz/#!ERt1DCrK!EnIbrixDe...WATz9aNvRHiDOg
    VVDI PROG latest software version V4.9.1 update
    v4.9.1 (2020-02-19)
    * This version DON't need update firmware
    + Add VVDI PROG USER MUNUAL 4.9.1version in Doc folder
    + Add ME17.3.0(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ABARTH>
    + Add MED17.1.10(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><AUDI>
    + Add EDC17CP54(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><AUDI>
    + Add EDC17C69(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ALFA-ROMEO>
    + Add MED17.3.3(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ALFA-ROMEO>
    + Add ME17.8.31(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ASTON-MARTIN>
    + Add MED17.7.5(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-> <ASTON-MARTIN>
    + Add MED17.7.7(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BENZ>
    + Add MED17.7.5(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BENZ>
    + Add ME17.8.3.3(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BENZ>
    + Add EDC17CP49(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BMW>
    + Add EDC17C76(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BMW>
    + Add MED17.1.12(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><BUGATTI-VEYRON>
    + Add EDC17C79(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><CHRYSLER>
    + Add EDC17CP52(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><CITROEN>
    + Add ME1717.9.20(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><DACIA-LOGAN>
    + Add EDC17C70(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><FORD>
    + Add EDC17CP42(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><FORD>
    + Add EDC17C58(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><HONDA>
    + Add ME17.9.21(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><HYUMDAI>
    + Add EDC17C83(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><ISUZU>
    + Add MED17.9.9(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><JAGUAR>
    + Add MED17.8.32(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><JAGUAR>
    + Add EDC17C79(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><JEEP>
    + Add ME17.9.21(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><KIA>
    + Add MED17.8.32(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><LANDROVER>
    + Add EDC17C79(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><MASERATI>
    + Add MED17.3.4(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><MASERATI>
    + Add ME17.8.3.3(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><MCLAREN>
    + Add MED17.1.27(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><VOLKSWAGEN>
    + Add ME17.5.24(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><SKODA>
    + Add ME17.5.26(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><SKODA>
  21. The Following 3 Users Say Thank You to kautuvera For This Useful Post:
    habbyb (24th February, 2020), PocketHero (24th February, 2020), weza247 (4th March, 2020)
  22. #3450
    Nov 2010
    cyprus
    hello someone to read for volvo cem with renessa m30855fw
