Page 238 of 290 FirstFirst ... 138188228233234235236237238239240241242243248288 ... LastLast
Results 3,556 to 3,570 of 4348
Thread: VVDI PROG
  1. #3556
    Feb 2013
    Dear Samic? When will you be adding this type of tricore TC2XXX? Thanks
  2. #3557
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by Liteace View Post
    Is it connected to the other ground or the ground of the unit or just a shield thats not connected to anything?
    it's playing with the crystal resonator freq and/or the power supply Strickly follow the pinouts and forget your multimeter, cable changing (lenght) just use and accept it
  3. The Following User Says Thank You to jodge For This Useful Post:
    Liteace (4th August, 2020)
  4. #3558
    It's connected to a GND pad near the CLK signal.
  5. #3559
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    Anyone with a solution to repair vvdiprog with only a solid red led and not being detected by the software. But when you use the update tool you can get serial number and frame ware version. Anyway to do reflash of this device?
    Sent from my SM-A605FN using Tapatalk
  6. #3560
    May 2014
    hello can vvdiprog rl78, line tool 0 is brown, orange or purple?
    solved...
  7. #3561
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    Quote Originally Posted by autocheck View Post
    Can someone help on this issue?
  8. #3562
    Maartinj's Avatar
    Nov 2010
    conbtact support over APP chat, or your dealer.
  9. #3563
    Maartinj's Avatar
    Nov 2010
    Here is a quick view how to post feedback / send message to tech support
  10. The Following 2 Users Say Thank You to Maartinj For This Useful Post:
    autocheck (11th August, 2020), immoneard (10th August, 2020)
  11. #3564
    p1et's Avatar
    Oct 2013
    Anyone tried to read Porsche BCM 1L15Y/1N35H/5M48H recently?
    We can find on this forum that some people got serious problems with corrupting data while reading or after reading the data.
    Is it still scary to read?
    For example BMW 5M48H/1N35H reading works very good so I guess Porsche should also be fine... (?)
  12. #3565
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Does 35160dw require adaptor like 35080
  13. #3566
    didi_du_93000's Avatar
    France Paris
    Quote Originally Posted by teerak2uk View Post
    No need adapter.
    Read: id, long id, data
    Transfert id and long id to xhorse emulator.
    Job done
    With Tapatalk
  14. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    teerak2uk (15th August, 2020)
  15. #3567
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by didi_du_93000 View Post
    No need adapter.
    Job done
    With Tapatalk
    Emulator? I'm using new 35160dw xhorse chip
  16. #3568
    ghostrider72's Avatar
    Jul 2012
    UK
    No need adapter. You can read it in circuit with clip
  17. The Following User Says Thank You to ghostrider72 For This Useful Post:
  18. #3569
    France Paris
    Original 35160dw can't change Id.
    So if you can change Id it's named "emulator".
    With Tapatalk
  19. #3570
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    With Tapatalk
    Using these
