Page 240 of 295 FirstFirst ... 140190230235236237238239240241242243244245250290 ... LastLast
Results 3,586 to 3,600 of 4422
Thread: VVDI PROG
  1. #3586
    hivrich's Avatar
    Sep 2012
    Ukraine
    Quote Originally Posted by Multipla View Post
    Were you buy your vvdi prog, can help for good vvdi? Tanks in advance.
    https://www.xhorsevvdi.com/wholesale...og-programmer/
  2. The Following User Says Thank You to hivrich For This Useful Post:
    Multipla (14th September, 2020)
  3. #3587
    Apr 2016
    uk
    I buy from @daxxer and Al good,always!
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
  4. #3588
    Quote Originally Posted by castin View Post
    Just for info EWS4.3 BMW E46 2006 read OK - car start.
    You read the flash or just eeprom?
    Majone
  5. #3589
    hackgsm's Avatar
    Default VW GW MQB HIGH MPC5607B_1M03Y
    HI ITS POSSIBLE TO READ THIS GW VW GW MQB HIGH MPC5607B_1M03Y THANKS
  6. #3590
    Romania
    I tried before but mcu is locked.
  7. #3591
    kumistheru's Avatar
    Aug 2013
    Default Mercedes VIT MC68HC912D60 SRS connections
    Pinouts from back of the board to read & write Mercedes VITO SRS module with MC68HC912D60.
  8. The Following 6 Users Say Thank You to kumistheru For This Useful Post:
    alclot (22nd September, 2020), ASCM (27th September, 2020), danielif (13th October, 2020), daxxer (16th October, 2020), KADE007 (18th September, 2020), Perryking (21st September, 2020)
  9. #3592
    castin's Avatar
    Oct 2015
    Quote Originally Posted by Majone View Post
    Majone
    Just eeprom.
  10. #3593
    Hi i just discovered a problem with the M95320 memory verification is related to firmware 4.9.5.
    The wrong file is verified as correct.
  11. #3594
    rob h's Avatar
    May 2011
    Explain that.
    Did you read in circuit first, then removed it?
    Only then you can be sure a 100%.
    Reading in circuit, takes skills, and experience.
    Read in circuit, then safe! Only then you verify.
    If verify is ok, remove clamp, reatached clamp, and Read one more time.
    If there are verify issues, lower voltage range from 2.75 to 3.75v.
  12. #3595
    I know a lot of interesting facts, many years in my profession.
    On version 494 it is ok 495 wrong
  13. #3596
    Aug 2018
    Bulgaria
    Hello to all friends using vvdi prog,can some one help me about how to read mcu renesas r5f10wmea,is from kymko bike dashboard,i try to read like r5fd-c 8kb secured and in 50percent of read give me read error ad stop,now dash shows 0km and needle for rpm not work,i have a good file 8kb with 27k km but when change option on vvdi to 8kb whrite give me erase error,plase gyis i need help not for free i pay paypall for working solution to read with vvdi prog!!!Thanks in advance.
  14. #3597
    I tried to read the data flash from R7F701330 mcu with my VVDI Prog but not success well.
    It read 94kb but data flash is only 64kb.
    In contrast it can read the code flash well.
    I tried to read it with SW 4.9.4 and 4.9.5 also.
    Do anybody have any idea?
    Thank you
    BR
    G
    Update:
    Problem solved.
    This mcu's data flash is devided
    It has data flash 1 (64kb)
    and data flash 2 (32kb)
    The VVDI Prog can read these in one block and it is 96kb.
  15. #3598
    Feb 2016
    United Kingdom
    interesting when Xhorse gonna finally sort problem with the main VVDI Prog exe file. My antivirus time after time deletes it. sometimes feeling like I`m using cracked software. btw using kaspersky
  16. #3599
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by BmwMerc View Post
    Uninsall antivirus, simple
  17. #3600
    Feb 2014
    Or the safer way - just add their software in AV exclusions.
