Page 278 of 295 FirstFirst ... 178228268273274275276277278279280281282283288 ... LastLast
Results 4,156 to 4,170 of 4422
Thread: VVDI PROG
  1. #4156
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by Maartinj View Post
    cool down that 2 parts
    if this happen again, add small radiator in there
    Thanks for the advice. If it makes it more stable I guess some cooling solution mod will happen to my vvdi prog...
  2. #4157
    Apr 2014
    hi guys. I am trying use my VVDIPROG since the last update. i am getting USB ERROR and no flashing green light
    i need your help urgently. thank you
    v5.2.6 (2023-03-24)
    >>>DOWNLOAD<<<
    * This version DON't need update firmware
    * The software added the function of saving read data to temporary file if read data fails.
    * Modify MQB-LOCK(D70F35xx) option in <5-DASHBOARD>-><VOLKSWAGEN>: Optimize the process and Wiring diagram update.
  3. #4158
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by trinicolin View Post
    Try changing usb cable. Error has nothing to do with update. Probably you are using your vvdi prog too rarely and your inner battery has died.
  4. The Following User Says Thank You to sniegavirs For This Useful Post:
    trinicolin (19th April, 2023)
  5. #4159
    svrecar's Avatar
    Does anybody have a pinout for vvdi for freescale mpc5644b ? 0n32e maskset.
    PLease and thank you.
    br,
  6. #4160
    right here right now
    can anyone help me out,i'm looking for a copy of older s/w version for vvdiprog,maybe v4.6-4.7 if possible
    cheers.
  7. #4161
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    anyone having frequency failed on new VAG dash d70F3529 mcu ive tried cut track and lift pin
  8. #4162
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by teerak2uk View Post
    show pcb and connection you did
  9. #4163
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Anyone using vvdiprog with vvdi2 to change km on new vag clusters as I'm looking for complete process I've already read mcu
  10. #4164
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    AliExpress seller said it don't change km
  11. The Following User Says Thank You to teerak2uk For This Useful Post:
    rtbdiagnostic (17th April, 2023)
  12. #4165
    Maartinj's Avatar
    Nov 2010
    can do as I said before
    load file, change km , and vvdi2 will generate new file witn
    0km or any other you need
  13. #4166
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Done it on 3 virtual clusters. Works great!
  14. #4167
    Maartinj's Avatar
    Nov 2010
    v5.2.7 (2023-04-18)
    >>DOWNLOAD<<
    + Add MB91F53BC option in <2-MCU>-><FYJITSU-MB9XF>
    + Add XC2361E-136 option in <2-MCU>-><INFINEON-XC2XXXX>
    + Add SPC5602D option in <2-MCU>-><ST-SPC560XXXX>
    + Add MQB-LOCK(D70F35xx)-READ, MQB-LOCK(D70F35xx)-WRITE, VW-4th-NEC35XX-READ, VW-4th-NEC35XX-WRITE, options in <5-DASHBOARD>-><VOLKSWAGEN>
  15. The Following 5 Users Say Thank You to Maartinj For This Useful Post:
    brend (19th April, 2023), dawidhubert (20th April, 2023), rtbdiagnostic (19th April, 2023), sniegavirs (19th April, 2023), solitaire (18th April, 2023)
  16. #4168
    Apr 2014
    Quote Originally Posted by sniegavirs View Post
    Are there any solution for this situation?
    Sent from my SM-A525M using Tapatalk
  17. #4169
    Maartinj's Avatar
    Nov 2010
    for dead battery - talk with seller
    for other hw issue - talk with seller
  18. The Following User Says Thank You to Maartinj For This Useful Post:
  19. #4170
    Apr 2014
    Just buy another one.
