THANK YOU, I will try & report back.
What cable do I need for VVDI
Hi mates,
Can anyone help me how to read this mcu please?
D76F0117 on vag bcm
Thanks a lot
I think you need to look under immobilizer section for audi/vw, if not look around. There should be connection for VAG BCM
learning by doing, learning by experience... please thx is I helped you
hi friends
with new software update i can't change partiton to manualy
how is possible change partition manualy in new updates ? to reading nfrm ? because not appear windows tu purpose it same as old version software
Hello !
Tuareg 2013 BCM2 secured NEC MCU ver 0503 VVDI prog won't read DATA 2 also VVDI2 don't know this version!
Is posibile add this BCM2 in VVDI prog and VVDI2 ?
Regards,
v5.3.0 (2023-08-30)
>>>DOWNLOAD<<<
* This version DON't need update firmware
* Modify GL8 BCM(2017--)-WRITE, option in <4-IMMOBILIZER>-><BUICK>: Optimize the process
+Add FENGSHEN S30(93C46A) option in <8-OTHER>-><Dongfeng>
dawidhubert (15th September, 2023), rob h (9th September, 2023), rtbdiagnostic (1st September, 2023), teerak2uk (31st August, 2023)
Hello, my vvdi-prog does not read FRM 3 mc9s12xeq384 3m25j frequency failed, it worked well. read write ok, and then stopped. I replaced the MC9S12 adapter but it does not read.
crafter ezs 9s12xdt384 read ok, FRM2 9S12XDT256 read ok.
how to solve a problem? or just the dealer?
"sorry google translate"
When you say, then stopped. Could you read, and write. And now it does not connect anymore?
So you have the ori frm data?
You could try the mcu menu.
Motorolas, enjoy warmt, some warm them slightly.
And sometimes, if it wont read, keep pressing read, until it reads.
Frm, never gave me a problem. Perhaps a update before, it was better.
i test both FRM with same problem "frequancy failed" and test menu to read MCU without success
the way is use old version and fixe manualy frenquency
i report this problem to support vvdi but nothing change and not give way ...
if anybody have old version working, share it![]()
i have my vvdi prog broken,the batery positive leg broken so now i have only red led light, the proggrammer is recognized by the pc but no yellow light blinking.
i bought it from somebody year ago so i dont know where is boughted.
can somebody provide a solution for this?
is oem i have the serial .
any more spam like what was in here and this account will be banned !!!
