Page 290 of 295 FirstFirst ... 190240280285286287288289290291292293294295 LastLast
Results 4,336 to 4,350 of 4422
Thread: VVDI PROG
  1. #4336
    Jan 2016
    YOU NEED TO REPLACE A FILE IN VVDI PROG TO Allow writing
  2. #4337
    Supas's Avatar
    Jun 2020
    Quote Originally Posted by cristofir View Post
    What question raised by your colleagues are you referring to?
  3. #4338
    peko's Avatar
    Hello
    i need read HC11A8 mask F92J
    But in wiring instruction i must connect grey wire CLK but not see wich on MCU v3 cable
  4. #4339
    hivrich's Avatar
    Sep 2012
    Ukraine
    MC68HC11A8 - pin 7(CLK)
  5. #4340
    ttzag's Avatar
    digital-kaos
    hello guys
    any one have pinout to read cluster on kia picanto 2018 MB91FXXX by vvdi prog ??
    i tried this method without success
    Actions speak louder than words
  6. #4341
    Sep 2015
    Quote Originally Posted by peko View Post
    Hello
    it's not grey, CLK is white cable in group 2. check MCU wiring in VVDI PROG. they just couldn't show white cable on white background
  7. #4342
    Sep 2015
    hi
    has anyone tried reading MB91F526 with success?
    trying to read CY91F526LKC from Alfa Romeo body ECU and can't read it - both dflash and pflash return FFs.
  8. #4343
    rob h's Avatar
    May 2011
    https://www.digital-kaos.co.uk/forum...nnections-help
    Not just you with vvdiprog.
    You could post partnumbers, and pinouts you tried.
    Connect and read id? Does it show you this?
  9. #4344
    Jul 2018
    Hi dear
    is it possible to use xhorse solder free adapter (MQB 3524) with other programmers (I have an adaptor that I would like to try with orange etc)
    or is there anyway to bypass MQB license authorization (which I don't have)
  10. #4345
    Jun 2016
    VVDIPROG freescale mac7241 write problem.
    I have a bmw srs with mcu freescale mac7241 I write flash but when I check it is totally different .
    can someone help me??
  11. #4346
    Usa
    Hello,will do cloning vvdi prog volvo xc60 cem 2011?
  12. #4347
    Sep 2021
    HellowIMG_20240412_180434.jpg! Is there any problems with wrighting spc560p34l1? I'm trying to clear crash in geely srs unit. Mcu reading is good, but when i try to write -erase error.
    P.s. sorry, if i post a question in a wrong thread.
  13. The Following User Says Thank You to Kostigan For This Useful Post:
    keymax (28th April, 2024)
  14. #4348
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Toyota spansion S6j3001lsj mcu used in corolla yaris etc can vvdi prog read and write
  15. #4349
    Top Poster KADE007's Avatar
    Jun 2019
    FRANCE
    Hi, anyone use vvdi prog to read/write Motorola's mcu? I Always use UPA for this job and now I need to read / write HC05 but UPA can write only eeprom area...
    I don't know if vvdi can make full write, i don't have the adapter for try...
    Envoyé de mon 23049PCD8G en utilisant Tapatalk
    The thanks button does not burn, you can press it without any risk !
  16. #4350
    May 2015
    My Tool Room
    Quote Originally Posted by figani View Post
    don´t know where exactly your problem is/was with 5607 with ford bcm...
    but I´ve done many successfully without any problem...
    In order to clone bcm ford ranger A2c74845003 continental black Bcm MPC5607B can i only read dflash and c flash and copy onto new bcm
    'If I helped, please click Thanks +Reputation.. !'
