Page 291 of 291 FirstFirst ... 191241281286287288289290291
Results 4,351 to 4,362 of 4362
Thread: VVDI PROG
  1. #4351
    Maartinj's Avatar
    Nov 2010
    v5.3.4 (2024-04-15)
    >>>DOWNLOAD<<<
    * This version DON't need update firmware
    * Software Update: Compatible with VP05 serial number programmer devices
    * Modify AM29F200xx, AM29F400xx, AM29F800xx options in <1-EEPROM&FLASH>-><AMD>: Write failure issue fixed
    * Modify R5F212L2SD, R5F212L2SN, R5F212L4SD, R5F212L4SN, R5F21364, R5F21365, R5F21366, R5F21367,
    R5F21368, R5F2136A, R5F2136C option in <2-MCU>-><RENESAS-R8C>: Wiring diagram update
    * Modify JIEFANG-J6-BCM option in <4-IMMOBILIZER>-><FAW>: Wiring diagram update
    * Modify R7F701333 option in <2-MCU>-><RENESAS-RH850>: Wiring diagram update
    * Modify R7F701312 option in <2-MCU>-><RENESAS-RH850>: connection failed issue fixed
    * Modify JETTA(2015-2020)(D70F3423), SANTANA(2015-2020)(D70F3423), C-TREK(2015-2020)(D70F3423) options in <5-DASHBOARD>-><VOLKSWAGEN>: Read exception problem fix
    * Modify MQB4.5_95320 option in <5-DASHBOARD>-><VOLKSWAGEN>: Wiring diagram update
    * Modify RATTAN-ZS option in <5-DASHBOARD>-><SAICMOTOR>: Wiring diagram update
    * Modify NEW-SANTAFE option in <7-AIRBAG>-><Hyundai>: connection failed issue fixed
    * Modify FENGSHEN S30(93C46A), FENGSHEN S30(93C46B) options in <8-OTHER>-><Dongfeng>: Wiring diagram update
    * Modify FAW BCM-3(MC9S12G128) option in <8-OTHER>-><FAW>: Optimize the process.
  2. The Following 5 Users Say Thank You to Maartinj For This Useful Post:
    dawidhubert (3rd June, 2024), hivrich (20th May, 2024), rtbdiagnostic (3rd June, 2024), teerak2uk (1st June, 2024)
  3. #4352
    Jan 2013
    italia
    Quote Originally Posted by shpuncik View Post
    ciao
    qualcuno ha provato a leggere MB91F526 con successo?
    provo a leggere CY91F526LKC dalla centralina della carrozzeria Alfa Romeo e non riesco a leggerlo: sia dflash che pflash restituiscono FF.
    hi friend by chance you solved it, I'm also trying to read MB91F526 with vvdi prog and I get a reading with FF
  4. #4353
    Mar 2021
    Hi, can you read and write 76f0040gd with vvdi prog?
  5. #4354
    Dec 2019
    Hi everyone. Did you try reading/writing flash on HC908AZ60A? Each time VVDI gets stuck on 99% and it seems that memory map is incorrect (does not correspond to HC908AZ60A data sheet)
  6. #4355
    rob h's Avatar
    May 2011
    You write, in circuit?
    What partnumber?
    Reading, ok, writing not ok?
    Data originated, from this part, or modified, or from another unit?
    Quote Originally Posted by opliuz View Post
  7. #4356
    Dec 2019
    Reading original data from OEM rear SAM unit (Mercedes W463 no mods done. Part Number A4635450101) in circuit fails at 99% and a temporary bin file is saved by VVDI in tmp folder. Upon inspection of temporary bin I can see that data is being read partially. It seems that incorrect memory maps are used by VVDI as bin data seems to be shifted comparing to other bin files from similar units where reading was done with xProg. Unfortunately I own only VVDI so I can't read the unit with xProg myself.
    As well VVDI is showing incorrect memory maps in their software when you select the MCU in question.
    MCU: Motorola HC908AZ60A mask 2J74Y
  8. #4357
    marek128's Avatar
    Jun 2012
    5.3.4 dont working on windows xp?
    If I help You. please say THANKS.
  9. #4358
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by marek128 View Post
    Didn't think anyone was still using xp
  10. The Following 2 Users Say Thank You to teerak2uk For This Useful Post:
    autoTkey (14th June, 2024), brend (14th June, 2024)
  11. #4359
    Dec 2019
    Any one can help ? im trying to write a range rover KVM virgin data by vvdi prog , it write successfully but no communication on the car , by other tool same data working perfectly !
    is there any hint to write this processor ?
  12. #4360
    The hint is to use another tool.
  13. The Following 2 Users Say Thank You to Diablotic For This Useful Post:
    corpin91 (21st June, 2024), qwojtus (15th June, 2024)
  14. #4361
    rob h's Avatar
    May 2011
    35080vp bmw dash, fail with adapter. XDPG11
    R270 clone, did in a few minutes
  15. #4362
    ttzag's Avatar
    digital-kaos
    mine is VP01..... will it work ??
    Actions speak louder than words
