hi friends
any succes to read SAK-C167CS ?
SAK-C167CS-L33M
hi friends
SAK-C167CS-L33M
Hi.
I need to clone A2139001722 with tricore TC277TP from Mercedes w205 control box, does anyone know how to do it, or which tool can I use successfully?
Here PinOut for read SAM Mercedes A-Class W169 SAM module control unit A1695454332 5DK008728-16
MCU:ST10F269 https://mega.nz/file/uM9F1L4Q#iuDAc_Pbca...RT07ZRSh0E
EEPROM:95080 https://mega.nz/file/bI0hFRQR#DvFq0NciB9...YpmGffyfuo
I use VVDI Prog for MCU, and Orange5 for read EEPROM in circuite.
I hope it will be useful for the forum users, and I hope Thanks and Reputations...
Don't forget to press the THANKS & REPUTATION button for help in the future.
Andreastech81 (20th November, 2024), CLK1201 (20th November, 2024), dawidhubert (20th December, 2024), Diablotic (12th November, 2024), dijo (4th February, 2025), electromech (13th November, 2024), ilkapali (30th November, 2024), jodge (9th February, 2025), KADE007 (12th November, 2024), MOBILTRONIC (25th February, 2025), rob h (12th November, 2024), rtbdiagnostic (20th November, 2024), scotlock (17th November, 2024), triak88 (15th January, 2025)
Any body have pin out for RFH 2022 ram for iprog or upa s or orange ?
Post your partnumber, and picture from the print, front and back.
There are 2 pcb versions rfhub
I have a problem with my VVDI prog - CAS3+ 0L15Y chip crack failure, I tried different MC9S12 cable, different CAS, soldering perfect and redone, and also changed power supplies, even though it has been working fine for the past few years with CAS3+ and many other modules but it seems this time it's likely given up.
Are u sure u use the 912 cable and not the other one,they look almost the same and the colors are the same
where I can find this tool ?
I was searching for hardware mate
https://www.vvdishop.com/wholesale/x...60dw-chip.html
this is a good price? does exist cheap version or only official one?
another question, I read at link above:
"£ means the type will be supported in the future.
ATMEL ATTINY £
ATMEGEA £
NEC uPD70F £
ST TMS370 £
MC9S12HY £
MC9S12HA £
MC9S12HZ £
MC9S12XHZ £
MC9S12B £
MC9S12GC £
MC9S12XS £
MC9S12K £
MC9S12Q £
MC9S12C £
MC9S12P £
MC9HC(9)08 £"
what tool I need to read/write NEC uPD70F ?
Corsa D VVDI Prog Renesas V850 70F3379 frequency failed
Hello. I'm just trying to read the Renesas V850 70F3379 MCU. The chip is in BCM corsa D. I have a "Try Frequency failed" error.
Does somebody tried to erase data from EEPROM B58253 24C02 with VVDI PROG. I connected WP pin 7 with pin 4 VSS Ground, but still cannot erase data. Read is possible.
