Page 51 of 291 FirstFirst ... 41464748495051525354555661101151 ... LastLast
Results 751 to 765 of 4360
Thread: VVDI PROG
  1. #751
    micromax's Avatar
    South Poland
    i always use it with xprog
  2. The Following 6 Users Say Thank You to micromax For This Useful Post:
    amigokola (29th October, 2016), eugen8 (8th November, 2016), garagetech007 (5th November, 2016), line44 (17th May, 2017), ttzag (28th October, 2016), xseva (26th September, 2018)
  3. #752
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by ttzag View Post
    Any one have a connection for read this w221 ism with ST10F269 ?
    wiring diagram is in VVDI Prog images i think
    many thanks to friend kevfield
  4. The Following User Says Thank You to daxxer For This Useful Post:
  5. #753
    ttzag's Avatar
    digital-kaos
    Its only for ism with 9s12 i think
    Actions speak louder than words
  6. #754
    Nov 2012
    Megane 3 985105478R airbag. 95640.
    Orange 5 clone xprog 5.51 clone, and upa clone, read's it in circuit.
    VVDI-PROG, reads al FF.
    M35080 was erased with r270, and vvdi can't do-it.... e65 dashboard.
    ? Maibe mine is broken.
  7. #755
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    right... is only for 3M25J
    but i see somewhere wiring for STxxxx, but now don't know, where it was....
  8. #756
    ttzag's Avatar
    digital-kaos
    mcu>st>st10fxxx
  9. #757
    Apr 2015
    Quote Originally Posted by autodigitec View Post
    (I'll post this here because I might not see you online on skype tonight.)
    Just received another programmer that reads it fine.
    Device id:
    10 7F 04 61 7F 7F 7F 8F 80 80 80 80 02 7F 7F 01 02 C4 37 B0 46 B3 B3 37 31 20 20 7F FF 00 00 00
    VVDIprog doesn't even reach that part, it stops after the first reply of the mcu.
    I recorded my other programmer reading it with Saleae Logic (v1.25), attached session and dump.
    thank you friend,checked dump,this programer use the default low baudrate 9600bps to read data.
    VVDI PROG changed baudrate to 153600bps to decrease read time
    baudrate change step:
    1.Use low baudrate 9600 wakeup the chip, if get the correct response,go to step2
    2.Start change baudrate, due to the d70f3624 doesn't know own osc frequency,programer need send it the accurate value
    (VVDI PROG put some common-used osc value,so you can see try frequency xxxxhz info)
    3.Programer send the new baudrate value to d70f3624, vvdiprog use 153600bps
    the d70f3624 can calculate the new baudrate with the osc value, but if the osc value is incorrect,you will get a wrong baudrate
    (eg: the actual osc is 4Mhz, if you set a 8Mhz osc value and change the baudrate to 153600bps the chip will set a 76800bps)
    4.Use the new baudrate to communicate
    Maybe the osc frequency is not in VVDI PROG osc value list
    Please grab a new dump with vvdiprog,need to further analyze of the problem.
  10. The Following 5 Users Say Thank You to Samic For This Useful Post:
    autodigitec (29th October, 2016), CaioW (4th November, 2016), daxxer (29th October, 2016), Hayssam1 (29th August, 2019), PremierD (29th October, 2016)
  11. #758
    Apr 2015
    Quote Originally Posted by dorofteius View Post
    please try to remove chip and read instead of in circuit.
    M35080 cannot support erase currently,still fixing.
  12. The Following User Says Thank You to Samic For This Useful Post:
  13. #759
    Nov 2012
    I did not do-it in circuit. 35080 i mean.
    I still have that chip.
  14. #760
    ttzag's Avatar
    digital-kaos
    for w221 ism with ST10F269 read by vvdi prog OK with micromax diagram (thank u).
    for write it didnt erase automatically you have to erase it before, then all OK .
  15. The Following User Says Thank You to ttzag For This Useful Post:
  16. #761
    micromax's Avatar
    South Poland
    all st10 must be erase before write.
  17. The Following 5 Users Say Thank You to micromax For This Useful Post:
    amigokola (29th October, 2016), AndyCZ (1st November, 2016), daxxer (29th October, 2016), ttzag (29th October, 2016), xseva (26th September, 2018)
  18. #762
    autodigitec's Avatar
    Aug 2011
    PT
    Quote Originally Posted by Samic View Post
    Thanks for looking into this, but I don't have the ECU anymore. If my clear file was not correct I will receive it again and test.
    OSC was 8MHz (it's the list and I tried manually)
    Working on something to release next month for free for all dk users :>
  19. The Following User Says Thank You to autodigitec For This Useful Post:
    daxxer (1st November, 2016)
  20. #763
    Dec 2015
    Mates i've got ews4 bmw try to read it with vvdi prog failed 5 times any idea ?
    NO ADVERTISING PLEASE
  21. The Following User Says Thank You to Nassreddine84 For This Useful Post:
  22. #764
    Apr 2015
    thank you friend,if 8MHz should be ok,very strange.if you can get new dump for further analyze,will fix this issue asap.
  23. The Following User Says Thank You to Samic For This Useful Post:
  24. #765
    Apr 2015
    Quote Originally Posted by Nassreddine84 View Post
    Frist ensure connection wires all ok.one more thing,Please DON'T lengthen/extend CLK & GND_C lines by yourself.
    because CLK & GND_C not only for connection line,but also use for signal communication lines.cannot replace by normal connection wires.
  25. The Following 3 Users Say Thank You to Samic For This Useful Post:
    daxxer (1st November, 2016), Nassreddine84 (2nd November, 2016), rola1971 (1st November, 2016)
