Page 62 of 295 FirstFirst ... 1252575859606162636465666772112162 ... LastLast
Results 916 to 930 of 4422
Thread: VVDI PROG
  1. #916
    Fallen's Avatar
    Quote Originally Posted by bearheroes View Post
    If you change battery it will work...i don't know the reason for this, but indeed happens.
    A lot of the keys bought off ebay have bad batteries that do not charge and will begin to discharge in the ignition bringing on the low battery warning.
    So you are correct, it is the battery fault not the firmware.
    Changing the battery for one in good condition will fix this issue.
  2. #917
    Feb 2012
    thank levanime
  3. #918
    Mar 2016
    South Africa
    anyone read this successfully
    with vvdi-prog?
    bmw bosch motronic
    dme 7620350
    0261s06901
    infinion tricore
    sak-tc1796
    i have tried with vvdi-prog but keeps saying crack fail
    is it a password problem perhaps or i dont have correct wiring diagram.
    i tried same way as fgtech pinout. my friends fgtech reads it perfect.
    any feed back would be nice thanks.
  4. #919
    PierreTheron's Avatar
    Centurion,South Africa
    If they add HC805P18 with read and write i might be interested ..
    I made some work on finding the pinout on this MCU So here it is ........................
  5. The Following User Says Thank You to PierreTheron For This Useful Post:
    lpf01 (5th February, 2017)
  6. #920
    Hello there
  7. #921
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    Quote Originally Posted by PierreTheron View Post
    I second you
    Sent from my A718 Xplora Plus using Tapatalk
  8. #922
    Jul 2016
    Tried to read a Toyota Avalon 2000 93C56 chip, it would read successful but when I load into vvdi2 it would say unknown version, it was right file size. How are you guys reading Toyota ?
  9. #923
    Dec 2015
    Quote Originally Posted by iHenry3 View Post
    On this toyota ecus i load vergin dump and cycle keys will work
    NO ADVERTISING PLEASE
  10. The Following User Says Thank You to Nassreddine84 For This Useful Post:
    habbyb (7th February, 2017)
  11. #924
    Jul 2016
    Quote Originally Posted by Nassreddine84 View Post
    which eeprom manufacture you use to load and write to chip?
  12. #925
    habbyb's Avatar
    Romania
    Hello,can you post dump here.I'll check for you.
  13. #926
    habbyb's Avatar
    Romania
    Hello everyone, VVDI prog It appears to be safe for cas 4 see recent video.https://www.youtube.com/watch?v=v-mQJCq02zw https://www.youtube.com/watch?v=4yU-acjchVE
  14. The Following 2 Users Say Thank You to habbyb For This Useful Post:
    daxxer (6th February, 2017), labusas (6th February, 2017)
  15. #927
    Jul 2016
    4T1BF28B6YU028216.rar
    Here's the Toyota bin file, I kept getting unknown file.
  16. #928
    habbyb's Avatar
    Romania
    Hello,your dump is corect check with many tools denso ecu 93c56.you can prepare the dump virgin or to program a key 4c ready to start.
  17. #929
    Jul 2016
    It wouldn't load to my vvdi2
  18. #930
    Aug 2015
    quest the memory is r57?
