Page 70 of 295 FirstFirst ... 2060656667686970717273747580120170 ... LastLast
Results 1,036 to 1,050 of 4422
Thread: VVDI PROG
  1. #1036
    Aug 2013
    Quote Originally Posted by duplikeytor View Post
    I try secure method and it read ID as FFFF. When I select to reset unlock, it cannot crack chip and says connection might be wrong
    Any idea? MC9S12XEG384CAL
    I checked connection and 100% right
    So of course, connection was not 100% right when I thought it was , I finally was able to read it via the programmer.
    ID of chip is correct and when clicking on Reset Sec
    [2017-03-22 16:49:01] : Backup the <2-MCU_MOTOROLA-MC9S12_MC9S12XEG384_SECURED> Reset Sec operation security area data in file: 20170322_164901_2-MCU_MOTOROLA-MC9S12_MC9S12XEG384_SECURED_backup_data.bin
    [2017-03-22 16:49:01] : Start communication...
    [2017-03-22 16:49:01] : Chip is not crypt FE
    [2017-03-22 16:49:01] : End communication...
    [2017-03-22 16:49:02] : Operation success
    Does this mean it's not secured?
    Also when trying to read D-Flash, it's empty, I only have EEE and P-FLASH
  2. #1037
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Yes...right thats mean this MCU is not secured
    i have read D-flash from ISM/DSM MCU and was empty too...
    many thanks to friend kevfield
  3. The Following 2 Users Say Thank You to daxxer For This Useful Post:
    duplikeytor (22nd March, 2017), habbyb (23rd March, 2017)
  4. #1038
    ibratex's Avatar
    Jul 2015
    angola
    Hello .
    Can you make pinouts with vvdi prog for mb91f061bs in suzuki jimny 2015 ?? Please
    Need help urgent please
    Enviado do meu SM-J320FN atrav?s de Tapatalk
  5. #1039
    Jul 2016
    Default vvdi prog fail to crack porsche
    Working on PORSCHE PANAMERA 2M25J MASK ID:C482, I Have tried to decrypt several times. I only get failure to crack check connections, I have removed the two components as shown in diagram. I have check connections still same issue.
  6. #1040
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by iHenry3 View Post
    picture is too small to see there something
    try to lift some pins like EXTAL and RESET, maybe help...
  7. The Following 3 Users Say Thank You to daxxer For This Useful Post:
    fytfh (1st April, 2017), iHenry3 (24th March, 2017), Nassreddine84 (25th March, 2017)
  8. #1041
    Jul 2016
    Quote Originally Posted by daxxer View Post
    when you have read this module in the past which leads you tried first ?
  9. #1042
    Aug 2013
    I
    I can confirm VVDI PROG have problem reading D Flash as I read the same board with SMOK and it read the EEPROM and P FLASH identical to VVDI PROG and also was able to read the D FLASH MEMEORY. SO VVDI PROG have problem reading D FLASH.
    Is the P and D FLash the same for the same mask across boards? And only the eeprom is different?
  10. #1043
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    I
    i try this same MCU read with Xprog too, but the same results....EEPROM+P-Flash ok, D-flash empty.
  11. #1044
    I have a question. Has anyone had any problems reading CAS 3 with 0L01Y mask. Is it safe to read with VVDI prog.
  12. #1045
    ttzag's Avatar
    digital-kaos
    Quote Originally Posted by testit34 View Post
    I read it many time ...its safe
    Sent from my SM-A520F using Tapatalk
    Actions speak louder than words
  13. The Following User Says Thank You to ttzag For This Useful Post:
    testit34 (25th March, 2017)
  14. #1046
    Thanks for the information
  15. #1047
    Mar 2017
    Colombia
    Hello excuse me. Someone tried to read ecu vw tricore
    TriCore tc1796 edc 17 successfully. ?
    thank you.
    WINNER THE LOSER
  16. #1048
    ibratex's Avatar
    Jul 2015
    angola
    Quote Originally Posted by ibratex View Post
    Hello .
    Any info mates ? Would apreciat
  17. #1049
    May 2016
    anyone knows how to read DFlash from working FRM3?
  18. #1050
    micromax's Avatar
    South Poland
    just click read. its working ;-)
    frm have eeprom and pflash, don`t use dflash
  19. The Following User Says Thank You to micromax For This Useful Post:
    CarCity (1st April, 2017)
