Page 71 of 295 FirstFirst ... 2161666768697071727374757681121171 ... LastLast
Results 1,051 to 1,065 of 4422
Thread: VVDI PROG
  1. #1051
    May 2016
    thanks,
    but i mentioned DFlash in my post,
    in the list its under MCU,
    but I already figured it out.
    you can read Dflash just in case if eee partition is damaged,
    in that case you can set size of Dflash and read it. otherwise, if eee partition is fine you cant set dflash size without erasing all data.
  2. #1052
    Maartinj's Avatar
    Nov 2010
    sometime you need manually adjust Dflash size , and is better to look if can read
    P-flash not all ,.
  3. #1053
    Jan 2017
    Hi, is there anyway of programming land rover smart keys via eeprom with vvdi prog?
  4. #1054
    electromech's Avatar
    Behind a large rock
    Quote Originally Posted by gilahish View Post
    I take it you are refering to KVM....vvdi can read these i am very interested to find a programmer to can put keydata in dump..
  5. The Following User Says Thank You to electromech For This Useful Post:
    gilahish (2nd April, 2017)
  6. #1055
    Quote Originally Posted by chli1976 View Post
    Can vvdi prog erase the first two lines in M35080 M35160 (80D0WQ, 160D0wQ) ?
    Can anyone check this please?
  7. #1056
    Sep 2016
    [QUOTE = YPT; 2997058] Может кто-нибудь проверить это, пожалуйста [/ QUOTE]?
    Hi, everybody. Something happened that now I ceased to erase D80 and D160
  8. #1057
    Aug 2015
    I dont like the wires of the vvdi prog, it would be better they can make kynar wires.
    Gesendet von meinem Nexus 5X mit Tapatalk
  9. The Following User Says Thank You to offsystem For This Useful Post:
    ttzag (3rd April, 2017)
  10. #1058
    Quote Originally Posted by Astronom View Post
    Sorry, but i dont understand what you said.
  11. #1059
    May 2013
    Hi there Guys.....
    So I have been impressed with the VVDI tools so far and now completed my VVDI equipment set by adding the VVDI prog.
    I bought the PCF79XX adaptor as well.........
    Can somebody help me with this thing? I have a few chinese BMW E90 keys with PCF7941. They were previously programmed on cars and therefore locked. I soldered the wires on the board as per diagram and selected PCF7941 In Circuit. Then I pressed reset security.......
    Now When I read transponder on any transponder machine it would just say UNKNOWN TRANSPONDER. So my guess is that the chip needs precoding.
    I then select REMOTES -> BMW THIRD PARTY. I open the file and press write but it says "CHIP NOT CONNECTED". The diagram also shows a key PCB which is very similar to Original keys.
    So my question is: CAN VVDI RESET the chinese BMW keys? If so then could somebody explain a procedure?
    Can we also do other keys like peugeot / citroen? How can I copy data from a brand new key with PCF7941 to one that was previously coded? Is it possible?
  12. #1060
    securipro38's Avatar
    EU
    HI
    Tried several times to read pcf 7941 from peugeot ket with pcf79XX adapter and in circuit without success
    If you can erase pcf7941 ,a new personalised file must be loaded to chip ,depend of key and version like mk3
    Have a look to this video with mk3 to undestand how pcf79XX works
    https://www.youtube.com/watch?v=4ttWyjHd3wM
  13. #1061
    May 2016
    you need to unsolder battery, if you have not done it
    i have not tried chinese, tried original board, worked fine
    btw it can not read or erase, it can only write
    I tried to find out info if it works with keyless go keys (comfort access) but support in chat could not answer
  14. #1062
    I tried 80D0WQ erase INC and did not work. Reading is fine.
  15. #1063
    When you choose Third party it still show diagram with Ori key and never work for me for china key.
    Ori key unlock for E series 100% ( of course supported one)
    Quote Originally Posted by obeids View Post
    Hi there Guys.....
  16. #1064
    May 2013
    Hi there guys......
    Why don't they add the HC05 chips as well? They should be able to make it use the Xprog adaptor sets as the pinout and layout is exactly the same........ Unless they want to add it with their own design so they can sell us more adaptors again.
    Also why can't they add the NEC chip function and we can use the NEC adaptor from our VVDI BGA tool? They should let us read and write the EEPROM and FLASH of the NEC.
  17. #1065
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Hi there guys......
    good idea i ask many times, why VVDI Prog still can't read HC05 for example...
    many thanks to friend kevfield
  18. The Following User Says Thank You to daxxer For This Useful Post:
    habbyb (9th April, 2017)
