Page 82 of 295 FirstFirst ... 3272777879808182838485868792132182 ... LastLast
Results 1,216 to 1,230 of 4422
Thread: VVDI PROG
  1. #1216
    habbyb's Avatar
    Romania
    In vag ecu add simos more obtion reading and unlock, vag bcm more obtion reading , tricore.....
  2. #1217
    Aug 2015
    Unlock function for secured NEC mcu but i belive that is only a dream from me.
  3. #1218
    Locksmith Hungary's Avatar
    Aug 2015
    Hungary, Pápa
    Quote Originally Posted by bearheroes View Post
    Vvdi can read all ecu with supported tricore...even msd80/81 with proper password...so bmsx and many F...
    Please search before posting.
    Thanks for the answer! I see you're a Prof!
    How i can read BMSX ECU with VVDIProg?
    Pls write the steps here.
    And what is the proper password?
    Tell me.
  4. The Following 4 Users Say Thank You to Locksmith Hungary For This Useful Post:
    exSPEEDyTOR (18th June, 2017), habbyb (18th June, 2017), lpf01 (18th June, 2017), sniegavirs (17th June, 2017)
  5. #1219
    spychu14's Avatar
    May 2011
    POLAND
    PCR2.1 Reading full flash. Like on X17 or Smok.
    Mac72xx MCU's
    Maybe additional adapter to read flash+ eeprom from HC08 unsoldered. Just like Orange or ETL.
    Secured V850 would be like a dream like someone said
    Also two types of connection to V850/ XC2xxxx (3wire/Uart) like in upa USB.
    MORE key PCF79xx data
    VAG
  6. The Following User Says Thank You to spychu14 For This Useful Post:
  7. #1220
    Mar 2016
    I just noticed that the 'third party" E series BMW renew looks exactly like the comfort access E series remote. It doesn't look like a Chinese clone at all. Has anyone tried it with OEM CA remote?
  8. #1221
    Nov 2014
    Hi mates
    Anyone read cas 3 0L15Y with vvdI prog
    I can read with vvdi prog.
    Have tried many version cant read.
    Can't bypass crack but read ID perfect.
    Am I doing something wrong. ..
    Thansk
  9. #1222
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by philipcoin View Post
    Hi mates
    Thansk
    Done it hundreds of times! Show some picture of pcb with wires soldered.
  10. #1223
    Jan 2016
    Hi mates
    Thansk
    If you use 4.5.8 version software, try with 4.5.7
    Envoy? de mon SM-A500H en utilisant Tapatalk
  11. #1224
    Nov 2014
    Thanks mate
    But I read with r270 successfully..
  12. #1225
    fixanycar's Avatar
    here
    BMW FRM repair has a definite glitch. I tried on 2 different FRM's. It does read it fast but no good result in eeprom manipulation. X-Prog does this slower (reading flash) but restores EEPROM good.
    Remote/Proxy key renew would be a nice add on.
    Otherwise, It has become my num 1 programming tool.
    ST72C334 mcu??? - 05 Maserati GT immo VIM220 + sync to the engine ECU
    Thanks VVDI team.
    "Xhorse added more engineers working on VVDI PROG, we decide to make a big update for VVDI PROG.
    currently we want to get feedback from our customer for the new update.
    1.which function require to add on VVDI PROG software,such as: we will add 'search' option.
    2.which chips/exactly module need to add.
    3.which problem/bugs still existing currently.
    4.other good idea or suggestion"
    New update will according to customers feedback, please post here/PM me, thanks in advance!
  13. #1226
    Feb 2016
    Quote Originally Posted by fixanycar View Post
    Thanks VVDI team.
    is the eeprom manipulated maybe because is messed in first place? or do you mean that you can fix eeprom from frm using xprog reading flash ?
    +thanks if I helped you!
  14. #1227
    Feb 2016
    bmw key renew for all keys would be nice, like F series Continental and E series Comfort Acces keys
  15. #1228
    fixanycar's Avatar
    here
    @ tibibond
    The eeprom gets corrupted in the flash
    Sent from my XT1650 using Tapatalk
  16. #1229
    Feb 2016
    @ tibibond
    please be patient with me, so if i write new flash, i will get communication on frm? im not an expert.
  17. #1230
    May 2016
    FRM repair works just fine,
    i do many of them, thru d-flash
