Page 90 of 295 FirstFirst ... 40808586878889909192939495100140190 ... LastLast
Results 1,336 to 1,350 of 4422
Thread: VVDI PROG
  1. #1336
    DK Veteran labusas's Avatar
    Nov 2010
    Thanks for your input. Anyone that has actually tried it. If not vvdi, can any other tool do it?
    Quote Originally Posted by Levanime View Post
    if i remember correctly X5 has MEVD172Y
    I dont think it can read it
  2. #1337
    Apr 2016
    USA
    Originally posted by TIBIBOND
    they will work as normal remote keys, because if you want to renew comfort acces keys you need dumps for CA keys...
    BRMTDI response
    They work as comfort access keys, every key I renewed which I did about 8, tested last night pairing to car....did 2 all worked....I am sure other 6 work perfect also....very impressed bravo xhorse
  3. The Following 2 Users Say Thank You to BRMTDI For This Useful Post:
    Levanime (21st July, 2017), sniegavirs (21st July, 2017)
  4. #1338
    Apr 2015
    VVDI PROG latest software version V4.6.0 update
    v4.6.0 (2017-07-26)
    * This version DON't need update firmware
    * Fix some bugs
    + Add VVDI PROG USER MUNUAL 4.6.0 version in Doc folder
    * Change some RENESAS-V850 chips DFLASH size to 64KB
    * Fix GM-BCM3 option
    * Fix V850E2 series diagrams
    * Change KESSY(2008--) diagram
    + Add V850E-SK3H,V850-SJ3H series diagrams
    + Add NM93CS06, NM93CS46, NM93CS56, NM93CS66, FM93CS06, FM93CS46,FM93CS56,
    FM93CS66 options in <1-EEPROM&FLASH>-><FAIRCHILD>
    + Add M93S06, M93S46, M93S56, M93S66, ST93CS46, ST93CS47, ST93CS56, ST93CS57,
    ST93CS66, ST93CS67 options in <1-EEPROM&FLASH>-><ST>
    + Add D80(ADAPTER), D160(ADAPTER), M350803(ADAPTER), M350806(ADAPTER), M35080V6(ADAPTER),
    M35080VP(ADAPTER) options in <1-EEPROM&FLASH>-><ST>(Need M35080/D80 ADAPTER)
    + Add MC9S12HN64_UNSECURED, MC9S12HZ64_UNSECURED, MC9S12HN64_SECURED,
    MC9S12HZ64_SECURED options in <2-MCU>-><MOTOROLA-MC9S12>
    + Add ST72321(R/AR)6, ST72F321(R/AR)6, ST72321(R/AR/J)7, ST72F321(R/AR/J)7, ST72321(R/AR/J)9,
    ST72F321(R/AR/J)9, ST72521B(R/AR)6, ST72F521(R/AR)6, ST72521B(M/R/AR)9, ST72F521(M/R/AR)9 options
    in <2-MCU>-><ST-ST7>
    + Add SPC5606S option in <2-MCU>-><ST-SPC560XXXX>
    + Add ME7.5.20(ST10F275) option in <3-ECU>-><VOLKSWAGEN>
    + Add KESSY(2008--) option in <4-IMMOBILIZER>-><AUDI>
    + Add KEYLESS-ENTRY-MODULE(2009--)option in <4-IMMOBILIZER>-><GM>
    + Add HAVAL-H9-BCM(D70F3632) option in <4-IMMOBILIZER>-><GREATWALL>
    + Add BCM(2009--) option in <4-IMMOBILIZER>-><LANDROVER>
    + Add XINBAO(MC9S08LG16) option in <5-DASHBORAD>-><CHANGAN>
    + Add CRUZE(D70F3423) option in <5-DASHBORAD>-><CHEVROLET>
    + Add DASHBORAD(2013--)(SPC5604S), DASHBORAD(2013--)(SPC5606S), FIESTA(3L16Y),
    FOCUS-C-MAX(2009) options in <5-DASHBORAD>-><FORD>
    + Add BESTURN-B70-SRS(D70F3623) option in <7-ARIBAG>-><FAW>
    + Add ACCORD-SRS(SPC56AP54L3) option in <7-ARIBAG>-><HONDA>
    + Add SRS-VW20(SPC560P50L3) option in <7-ARIBAG>-><VOLKSWAGEN>
    + Add A4L-LEW-MODULE(2013) option in <8-OTHER>-><AUDI>
    + Add EVOQUE-EPB-MODULE(2013) option in <8-OTHER>-><LANDROVER>
    Notes: please use latest software version, any problem post here/PM me.
  5. The Following 16 Users Say Thank You to Samic For This Useful Post:
    CarCity (26th July, 2017), chli1976 (26th July, 2017), damih (26th July, 2017), daxxer (26th July, 2017), derdud (1st August, 2017), electromech (26th July, 2017), fytfh (27th July, 2017), habbyb (26th July, 2017), keyantic (26th July, 2017), rola1971 (26th July, 2017), sniegavirs (26th July, 2017), solitaire (26th July, 2017), sv2hqx (27th July, 2017), ttzag (27th July, 2017), weza247 (26th July, 2017), yui (27th July, 2017)
  6. #1339
    electromech's Avatar
    Behind a large rock
    Does the users of VVDI PROG have to get VVDI KEY TOOL to have access to all the renew key dumps as we only really have BMW I find it pointless seeing we have invested and its one company that we should buy another tool just for access to PCF dumps.
  7. #1340
    May 2016
    Quote Originally Posted by Samic View Post
    which adapter is meant here?
    one that comes with vvdi prog or additional other one?
    Ok I figured out It is additional adapter,
    where do we buy it?
  8. #1341
    May 2017
    buy from the dealer
  9. #1342
    May 2016
    Quote Originally Posted by louis21 View Post
    buy from the dealer
    I cant find anywhere
  10. #1343
    May 2017
    sorry,forgot to say:it is still under producing.soon
  11. #1344
    Maartinj's Avatar
    Nov 2010
    where do we buy it?
    M350803 and other is SOIC 8 size , so use existing adaptor to read
  12. The Following User Says Thank You to Maartinj For This Useful Post:
    labusas (26th July, 2017)
  13. #1345
    May 2016
    Quote Originally Posted by Maartinj View Post
    yes,
    but it says it needs adapter, and even picture changes when u choose them, thats why I asked
  14. #1346
    May 2017
    yes,the existing adapter can read before,but can't erase,now the new M35080/D80 adapter can not just read but also can erase,so it's more useful for you
  15. The Following User Says Thank You to louis21 For This Useful Post:
  16. #1347
    sv2hqx's Avatar
    Jun 2014
    So if it's available can you post here??
  17. #1348
    Essex
    OK i have a unit here i bought to play with , there are many options on reading this unit
    little confused so please advise
    also will VVDI2 process to make a working chip to start vehicle ? as doesnt support unit unless is PIC typeIMG_3292.JPG
  18. #1349
    Nov 2012
    But not to erase . Allot off bla bla.
  19. #1350
    PierreTheron's Avatar
    Centurion,South Africa
    Pic 16f252 would be appreciated for next update
