Page 91 of 295 FirstFirst ... 41818687888990919293949596101141191 ... LastLast
Results 1,351 to 1,365 of 4422
Thread: VVDI PROG
  1. #1351
    ecumix's Avatar
    Apr 2014
    Default bcm2 8k0907064Ah
    Hello i need advice i have bcm 8k0907064 need clone i read nec70f3380 but the file read only 384kb i think should be 512 ?
    Please correct me ? if iam wrong ?
    READ BY VVDI PROG
  2. #1352
    ecumix's Avatar
    Apr 2014
    Default file from bcm2 ead vvdi prog
    FIle read vvdi prog
  3. #1353
    May 2017
    @sv2hqx OK
    @squirrelbandy It depends on what you want.If make a key of the range rover pic18f6620,should go to the 2-MCU,PIC18F,PIC18F6620 read the 1KB eeprom then load it into vvdi2.
    @PierreTheron I'll give some advices to them!
  4. #1354
    Essex
    this new unit added is not pic type its a 9s12 not covered for making keys
    the pic type is different unit !!
    this is why im asking simple question , 2 different types of unit i have both types in front of me , new 1 added ive asked the question about not the older PIC type
  5. #1355
    Hi @Samic
    I want do read Volco CEM,it is Renesas R32C R5F64524KFD 144 PINS.
    Can you please add this to VVDI Prog ?
  6. The Following User Says Thank You to mikolodz For This Useful Post:
    antotechaustin (7th September, 2017)
  7. #1356
    DK Veteran labusas's Avatar
    Nov 2010
    Tried to read AUDI S5 2013/09 BCM. It connects and says initialization success, but fails with Device error.
    VVDI2 failed even to make a connection to it.
    Samic what is the reason please?
  8. #1357
    May 2017
    sorry,something is abnormal.deleted
  9. #1358
    May 2017
    @ mikolodz OK,got it.I will come up it with the R&D
    @labusas if it's reminded like this,it's likely the wiring connection problem,please check it again.
  10. #1359
    Apr 2015
    Quote Originally Posted by PierreTheron View Post
    Pic 16f252 would be appreciated for next update
    checked and we can add this chip, but maybe not in next update.
    because we are adding other functions,such as HC05 adaptors.
  11. #1360
    Apr 2015
    Quote Originally Posted by ecumix View Post
    READ BY VVDI PROG
    friend,i think you directly select the option: 4-IMMOBILIZER-BCM2,but this option only available for 3379 or 3381/3634 currently,the pflash size 384KB.
    if you want to get 3380 type 512KB,you can select 2-MCU-V850-D70F3380,same connection diagram as before on your PCB.
    we also will add 3380 option on immo option.(they all Dflash same size,Pflash different.you can check each type memory size on MCU-V850ES diagram)
  12. #1361
    Apr 2015
    Quote Originally Posted by mikolodz View Post
    Hi @Samic
    yes friend,we can add.could you provide me the exactly CEM type and clearly PCB photo,
    we want to find this unit for testing before release.
  13. #1362
    Apr 2015
    Quote Originally Posted by labusas View Post
    usually if device error you can not connect, please show me the error screenshot.i will try my best to solve your problem.
  14. #1363
    solitaire's Avatar
    LT, jonava
    I think mcu locked
  15. #1364
    Quote Originally Posted by Samic View Post
    CEM part number is BG9T-14C256-GA it is from Volvo XC60.
    I ordered a new CEM for this car, when I receive a parcel with it I make a photo. Old CEM is in bad condition for make a photo
    Connection and some photo you can find in this topic:
    http://www.digital-kaos.co.uk/forums...ht=R5F64524KFD
  16. #1365
    LauAlf's Avatar
    EDC17CP14 not read.
    Enviado do meu SM-G935F através de Tapatalk
