Page 217 of 290 FirstFirst ... 117167207212213214215216217218219220221222227267 ... LastLast
Results 3,241 to 3,255 of 4349
Thread: VVDI PROG
  1. #3241
    p1et's Avatar
    Oct 2013
    Renesas v850 D07F3633 read/write both D_Flash and P_Flash 100% OK.
  2. The Following 5 Users Say Thank You to p1et For This Useful Post:
    danielif (25th August, 2019), Hayssam1 (30th August, 2019), PocketHero (26th August, 2019), taxo1965 (27th August, 2019), vasa (30th August, 2019)
  3. #3242
    Mar 2017
    Bogot? D.C., Colombia
    Hi, have any of you been able to read the BCM T4 N2VS with MCU ST-SPC560B60L5 for Renault Logan II Model 2017?
    Is it possible?
    Thank you for their answers.
  4. #3243
    Top Poster raptors's Avatar
    serbia
    I'm interested in how I can read full flash from pCR2.1 with VVDI PROG. The connection is clear to me but did not know how to put it in ecu boot to read the VVDI PROG. Do you use resistors at GALLETTO V54 or otherwise.
    Thank you for your help.
  5. #3244
    Apr 2014
    Any pin out SIM2K-241?
    Sent from my SM-G930F using Tapatalk
  6. The Following User Says Thank You to trinicolin For This Useful Post:
    Jobeso66 (28th August, 2019)
  7. #3245
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by Proteccion Car View Post
    Is it possible?
    I know people who tried and failed because it's somehow protected by Renault and cannot be read. But maybe someone have solution...
  8. #3246
    alclot's Avatar
    Melee Island
    Hi mates,
    Can anyone help me with the pinout to read this mercedes unit?
    Thanks in advance
  9. The Following User Says Thank You to alclot For This Useful Post:
    McDowell (2nd September, 2019)
  10. #3247
    Maartinj's Avatar
    Nov 2010
  11. The Following 8 Users Say Thank You to Maartinj For This Useful Post:
    datapage (30th August, 2019), dorofteius (29th August, 2019), habbyb (30th August, 2019), hojo25 (1st September, 2019), p1et (29th August, 2019), PocketHero (29th August, 2019), super jumbe (6th September, 2019), u.s (29th August, 2019)
  12. #3248
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by alclot View Post
    Hi mates,
    Thanks in advance
    This is HC05 or HC08?
  13. #3249
    keymax's Avatar
    Hi mates,
    Thanks in advance
    Remove it. It’s an HC05. Don’t try reading incurcuit. One bad connection and you’ll corrupt.
    Wouldn’t use the vvdiprog either.
    Original Xprog works great.
  14. The Following User Says Thank You to keymax For This Useful Post:
    alclot (30th August, 2019)
  15. #3250
    p1et's Avatar
    Oct 2013
    Clone Xprog also great for HC05, I read many HC05 with 5.0 clone and always work.
  16. The Following User Says Thank You to p1et For This Useful Post:
  17. #3251
    keymax's Avatar
    Quote Originally Posted by p1et View Post
    He’s telling the truth. I keep a couple hidden away just in case.
  18. #3252
    lion0304's Avatar
    Oct 2014
    The best xprog clone is 5.5.1 and there are no problem to read HC05 with adapter.
    Orange 5 clone work also great HC05 on adapter and many others
  19. #3253
    May 2016
    Russia
    Quote Originally Posted by sadarmeng View Post
    Anyone have read renesas 70F3577 daihatsu BCM? i have read new bcm but cant stable, every read, always displays different data, I try the environment Read + verify, always ask to be reset, after that device error, does my vvdiprog have a problem?
    Does anyone have dumps from the block?
  20. #3254
    Apr 2015
    VVDI PROG latest software version 4.8.6 update
    v4.8.6 (2019-9-02)
    * This version DON't need update firmware
    + Add VVDI PROG USER MUNUAL 4.8.6 version in Doc folder
    + Add ME17.5.22(TC1724)(ADAPTER), MEVD17.2.4_Exx(N20)(ADAPTER), MEVD17.2.4_Exx(N20)(ADAPTER), MEVD17.2.4_Fxx(N20)(ADAPTER),
    MEVD17.2.9_Fxx(N20)(ADAPTER), MEVD17.2.9_Exx(N20)(ADAPTER), MED17.5.25(TC1782)(ADAPTER), MED17_5_22(TC1782)(ADAPTER),
    MEVD17_2_3(B38)(ADAPTER), MEVD17_2_K(B38)(ADAPTER), MEVD17.2.5(ADAPTER), MEVD17.2.8(ADAPTER), MEVD17.2.H(ADAPTER),
    MEVD17.2.P_Fxx(N20)(ADAPTER), MEVD17.2_Fxx(N55)(ADAPTER), MEVD17.2.G(N55)(ADAPTER),MEVD17.2.6(N55)(ADAPTER)
    options in <10-BOSH-ECU-ADAPTER>-><BMW> (Need BOSH ECU ADAPTER)
    + Add ME17.5.22(ADAPTER), MED17_5_25(ADAPTER) options in <10-BOSH-ECU-ADAPTER>-><VOLKSWAGEN>(Need BOSH ECU ADAPTER)
    download link:
    https://mega.nz/#!Po5XBYBJ!ohwyr2AxA...L4oLekAxuTxN80
  21. The Following 10 Users Say Thank You to Samic For This Useful Post:
    alclot (4th September, 2019), andresvargas704 (3rd September, 2019), CarCity (3rd September, 2019), daxxer (3rd September, 2019), habbyb (3rd September, 2019), p1et (3rd September, 2019), polys123 (3rd September, 2019), rola1971 (3rd September, 2019), ThiagoArgentino (3rd September, 2019), vanos batam (3rd September, 2019)
  22. #3255
    Feb 2014
    Yeah, even after so many updates of VVDI Prog cheap Xprog clone still better on Motorolas...
