Chinese friends, never distinguished by legality, the file "NetClient.dll" and VVDI.exe -- packed "VMProtect packer" without a license, or roughly stolen.
Therefore more or less authoritative Antivirus this file will be will remove..
at one time many viruses were packed by a stolen packer... :/
Hi my VVDI Prog go off, i have a clicking sound around arround 12v dc connector and this zone is heat. The red led flashes with noise rythm... any had this fault? the computer not detect usb, surely must have a overcurrent. I tested diodes and are ok, i change voltage regulator near of heating zone am311117m and mp1584en, but not luck.
habbyb (19th November, 2019)
Any plan to make VAG MED17.1 working? By bosch adapter or by boot pin? It is listed but reading failing hardware 8k2907115L
My post helps you? Please Hit Buttons
You're question don't make sense
1. for sure using proper power supply, i do bmw ecu often
2. bosch ecu cable? look at software it uses normal ecu cable not bosch ecu cable. maybe they can make it work by bosch cable in update\
Also yes I have both normal and bosch ecu cable, and used them both on bmw ecu, boot mode and bosch cable without opening
VW MED17.5 says it canīt find the right Security Bytes for a TC1766
Anyone else had that ?
ERROR DO NOT read EPP 1L59W MC9S12DT128 MB EZS W209, Xprog Ok
I have read this same memory in ELV A6 and CIM opel.
any error with EZS ??
excuse my English, is the best.
