Anyone did Jimny 2016 MB91F061 dash before? I can read dump but get write error at 0%
Hi there
Now i see that is special thread about Vvdi prog...
I have "misunderstandings" with immo box from old car...
So mcu is Motorola 0j66d I am try to read with option immo box fiat immo box 0j66d but no successful...them I desolder and try direct like on vvdi blog how to read hc08 and still nothing (but did not solder 8mhz crystal)...
Car is lancia Lybra 2003y and immo box is imm100.10.
Is there solution or who did read this mcu or any help..
IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
PocketHero (29th May, 2020)
4.9.4 changelog?
Diablotic (27th May, 2020)
VVDI PROG latest software version V4.9.4 update
>>>DOWNLOAD<<<
v4.9.4 (2020-05-26)
* This version DON't need update firmware
+ Add VVDI PROG USER MUNUAL 4.9.4 version in Doc folder
+ Add R7F701330 option in <2-MCU-><RENESAS-RH850>
+ Add FENGJUN-7 option in <5-DASHBOARD-><GREATWALL>
+ Add TOYOTA-RAV4 option in <5-DASHBOARD-><TOYOTA>
+ Add BAOJUN-310/560 AIRBAG option in <7-AIRBAG-><SAICMOTOR>
+ Add T300 AIRBAG option in <7-AIRBAG-><ZOYTE>
+ Add NEW VISION AIRBAG option in <7-AIRBAG-><GEELY>
+ Add BAODIAN AIRBAG option in <7-AIRBAG-><JMC>
+ Add LYNKCO-AIRBAG option in <7-AIRBAG-><LYNKCO>
+ Add SRS-VW62 option in <7-AIRBAG-><VOLKSWAGEN>
+ Add AUDI-AC-CONTROLLER(R7F701548) option in <8-OTHERS-><AUDI>
+ Add FRM-E-SERIES-XDT256 option in <8-OTHERS-><BMW>
+ Add ESCORT-BCM option in <8-OTHERS-><FORD>
+ Add 8th-SONATA-AC-CONTROLLER option in <8-OTHERS-><HUNDAI>
+ Add SKODA-RADIO-STREAM option in <8-OTHERS-><VOLKSWAGEN>
Not much use in this new update - still missing some important Motorola MCUs.
Hello why xhorse does not add cas4/cas4+ editor in menu why hexprog it have that?
Sent from my SM-J415F using Tapatalk
I have w211 HC12 EIS 211 545 10 08 (I guess 3K91D). VVDI Prog manual say use cable V3 but on picture with connection there is V1 cable (it tell to use V2 or modify V1).
So which cable do I need to use? After I've seen that, I decided to first try with R260 blue clone but it keeps linking and can't communicate with MCU.
I'm gonna try with VVDI but need be 100% sure which cable to use, in order to avoid (or minimalize) risk with that tricky 3k91d.
I have xprog also which I used once in the pasgt with this mask and all good (auto verify OFF) but seen multiple opinions that xprog damage them also:
UPDATE:
OK I tried with V3 cable, communication OK, reading completed but file filled with zeros.
So I tried my Xprog 5.0 clone and voila, read succesfull, keys generated and EIS is working with new keys
UPDATE 2: Blue R260 clone also read this MCU no problem but with some software trick.
Anyone succeed reading W211 HC12 EIS with VVDI Prog recently?
p1et (1st June, 2020)
