HELLO
I WANT KNOW IF VVDI PROG CAN READ 68HC805 FOR IMMO MAZDA 323
HELLO
No. It can't.
It cannot read hcx05 at all.
daxxer (2nd November, 2016)
friend,about rover cem please check your connection wires and try again should be ok.
directly select 2--MCU--PIC18F6620(read all 0 means crypted type,read protected) is different between 4--IMMOBILIZER(use a special way to read).
select 4--IMMOBILIZER and try again,if still cannot read let me know.
Hi samic
i have a w211 hc12 eis
my mcu reflash cable is version 2
and i try to read eis with no success
keeps fail to crack chip
i try remove resistor also same issue
can you advise??
thank u
I need to make an A5 2008 all key lost.
Through obd cannot connect, so i deceided to take out bcm2. As in connection cannot read bcm2, read with orange5 but software says cannot support.
I have VVDI prog too but cannot see this chip in the list 70F3239.
Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
Maybe silly question but did you turn on/off lights, hazard lights, push brake pedal to have communication with BCM by OBD ??
BSI 307 2002 912DG128 - 3K91D
EEP (read and write) - OK
FLASh 4.000Mhz (read and write) -OK --- Orange5 clon (DO NOT write flash)
Identical files Vvdiprog and Orange5, same EEP and FLASH.
Incircuit BSI photo of Orange5.
Thanks Samic. :-)
Only need to Calculate PIN.
excuse my English, is the best.
Any one get successfully renew BMW PCF7953 remote ?
I renew PCF7953 - transponder is unlocked now but remote not working at all
remote was working before renew,
AVDI - have some but and after program key remote was working but car didn't start - after renew remote not sending any signal.
chack may be you write wrong dump
i have to same problem
but after doubel chack i write new hile and all work
EZS 906 A9069008600 OK
EZS 220 A2155450208 OK
vvdi 4.5.1 D70F3571 read ok
