Page 52 of 290 FirstFirst ... 242474849505152535455565762102152 ... LastLast
Results 766 to 780 of 4350
Thread: VVDI PROG
  1. #766
    Nov 2009
    tested range sports rover cem not work
    it start to read from 0% and it say error read in the 4 immobiliser tap
    but if i choose 2mcu
    and pick pic18f6620 it read ok but all 000
  2. #767
    Feb 2016
    HELLO
    I WANT KNOW IF VVDI PROG CAN READ 68HC805 FOR IMMO MAZDA 323
  3. #768
    Nov 2012
    No. It can't.
    It cannot read hcx05 at all.
  4. The Following User Says Thank You to dorofteius For This Useful Post:
    daxxer (2nd November, 2016)
  5. #769
    Apr 2015
    Quote Originally Posted by addgsm View Post
    friend,about rover cem please check your connection wires and try again should be ok.
    directly select 2--MCU--PIC18F6620(read all 0 means crypted type,read protected) is different between 4--IMMOBILIZER(use a special way to read).
    select 4--IMMOBILIZER and try again,if still cannot read let me know.
  6. The Following 3 Users Say Thank You to Samic For This Useful Post:
    CaioW (4th November, 2016), daxxer (3rd November, 2016), rola1971 (4th November, 2016)
  7. #770
    Apr 2010
    Hi samic
    i have a w211 hc12 eis
    my mcu reflash cable is version 2
    and i try to read eis with no success
    keeps fail to crack chip
    i try remove resistor also same issue
    can you advise??
    thank u
  8. #771
    lpf01's Avatar
    Oct 2013
    I need to make an A5 2008 all key lost.
    Through obd cannot connect, so i deceided to take out bcm2. As in connection cannot read bcm2, read with orange5 but software says cannot support.
    I have VVDI prog too but cannot see this chip in the list 70F3239.
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  9. #772
    Jan 2016
    Maybe silly question but did you turn on/off lights, hazard lights, push brake pedal to have communication with BCM by OBD ??
  10. #773
    lidons's Avatar
    Feb 2011
    BSI 307 2002 912DG128 - 3K91D
    EEP (read and write) - OK
    FLASh 4.000Mhz (read and write) -OK --- Orange5 clon (DO NOT write flash)
    Identical files Vvdiprog and Orange5, same EEP and FLASH.
    Incircuit BSI photo of Orange5.
    Thanks Samic. :-)
    Only need to Calculate PIN.
    excuse my English, is the best.
  11. #774
    filutek's Avatar
    Aug 2009
    Silesia
    Quote Originally Posted by lpf01 View Post
    70F3239
    UC2 Flash technology
    16 bytes Write
    512K byte Flash size.
  12. #775
    kazikk's Avatar
    Dec 2008
    Poland
    Any one get successfully renew BMW PCF7953 remote ?
    I renew PCF7953 - transponder is unlocked now but remote not working at all
  13. #776
    Dec 2015
    Quote Originally Posted by kazikk View Post
    Check ur remote key some time remote china made is low quality bmw does not accept the remote car will only start
    Thanks Reputation plz
    NO ADVERTISING PLEASE
  14. #777
    kazikk's Avatar
    Dec 2008
    Poland
    remote was working before renew,
    AVDI - have some but and after program key remote was working but car didn't start - after renew remote not sending any signal.
  15. #778
    rola1971's Avatar
    Jun 2014
    Dublin
    chack may be you write wrong dump
    i have to same problem
    but after doubel chack i write new hile and all work
  16. #779
    Jun 2012
    Russia
    EZS 906 A9069008600 OK
    EZS 220 A2155450208 OK
  17. The Following 3 Users Say Thank You to vasiliev7719 For This Useful Post:
    Atex31 (11th November, 2016), daxxer (11th November, 2016), ttzag (11th November, 2016)
  18. #780
    Sep 2016
    vvdi 4.5.1 D70F3571 read ok
