Page 9 of 295 FirstFirst ... 45678910111213141959109 ... LastLast
Results 121 to 135 of 4423
Thread: VVDI PROG
  1. #121
    Mar 2010
    Did you have to lift legs or remove parts?
  2. #122
    Oct 2015
    Soviet Union - USSR
    Hi. need cutting 2 wires. use the picture. if you have software. see manual, variant 4.2015-10-16 09-18-20 Скриншот эк&#108.jpg
  3. #123
    Mar 2010
    I tried today on V2 Cas4. I was able to read D Flash and P flash but it wont let me reset Sec so I can program unit.
    When you try to reset sec says Chip is Crypt FF Operation Failed. Any ideas ??
  4. #124
    CryptoKey's Avatar
    Jul 2015
    Europe
    HI Samic.
    CAS2 with 2K79X, there are two versions one can not read.
    ID-2K79x not recognize possible that another pinout, R270 says "NOT 5v Power" with the same connection that standard version of the image.
    - You could look and reprar this ruling.
    CAS2 I have this test,
  5. #125
    Mar 2010
    The cas I tried to do is CAS4 5M48H with Silver Crystal. It wont unlock Sec byte to program CAS.
    But you can Read D flash and P flash no problem and data is valid.
    You just cant unlock to edit data and rewrite.
  6. #126
    Apr 2015
    Quote Originally Posted by CryptoKey View Post
    HI Samic.
    Hello friend,the connection diagram of this type will add in next version.
    this type of the connection diagram is only a little different about the "CLK",other connection lines are the same.
    you can refer to this image,then try again.
  7. The Following User Says Thank You to Samic For This Useful Post:
    DashProg (19th October, 2015)
  8. #127
    Apr 2015
    Quote Originally Posted by testit34 View Post
    thank you feedback this issue,we will check and fix this problem.
  9. The Following 2 Users Say Thank You to Samic For This Useful Post:
    DashProg (19th October, 2015), folarinm (30th October, 2016)
  10. #128
    Apr 2013
    is good tool but now ther's vvdi2 2000 D
  11. #129
    CryptoKey's Avatar
    Jul 2015
    Europe
    SAMIC, this pin, not works. for VVDI-Prog
    cas2-V2 2K79X - siemens 59510.21.01C
    does not identify the MCU, I get in the ID0000 software.
    R270 also tells me (Not 5v Power).
  12. #130
    Moderator
    PremierD's Avatar
    Jun 2009
    Probably something to do with the thermal lance you used to throw solder at it from 20 meters away mate
  13. The Following 6 Users Say Thank You to PremierD For This Useful Post:
    Atex31 (23rd October, 2015), bursuc (25th March, 2016), clusters (23rd October, 2015), Johnner (23rd October, 2015), luis12 (6th August, 2016), smokey08 (23rd October, 2015)
  14. #131
    Dufner
    Johnner's Avatar
    Jun 2010
    Éire
  15. #132
    CryptoKey's Avatar
    Jul 2015
    Europe
    Age takes its toll on the eyes, but is well tested.
    ---Nothing, not leaving it beautiful, this is not working.
    -PremierD Now after it clean you should tell me what is the pinout,,
  16. #133
    clusters's Avatar
    Mar 2015
    Canada
    Then the facility that rebuilds clusters for GM must be full of geriatrics.
    A sample of their "reflow" work in a rebuilt cluster that failed.
  17. The Following User Says Thank You to clusters For This Useful Post:
  18. #134
    Apr 2015
    please use the current latest V3.9.1 version.
  19. #135
    CryptoKey's Avatar
    Jul 2015
    Europe
    found in all the versions, always the same. NOT ID-0000
    MCU - 9S12DG256 also beaten.
    this does not work!!!, nor welding, nor versions, all checked ..here the technical VVDI-PROG he stayed asleep.
