Page 22 of 295 FirstFirst ... 1217181920212223242526273272122 ... LastLast
Results 316 to 330 of 4422
Thread: VVDI PROG
  1. #316
    rob h's Avatar
    May 2011
    Quote Originally Posted by gigitalfvdi View Post
    win10 64
    yes admin
    scanner off
    driver allow
    winxp work ok
    I use w8 64 myself. No problems here!
    Do you see the device, in the manager popin up?
  2. #317
    Jun 2010
    win10 64
    yes admin
    scanner off
    driver allow
    winxp work ok
    I tryed win 10 and I didn't made it work.
    With win 7 and xp it worked fine.
  3. #318
    rob h's Avatar
    May 2011
    Quote Originally Posted by sakta View Post
    Does xhorse recommend windows 10?
    windows 8 64 bit works fine.
  4. #319
    Feb 2013
    Dublin
    Hi guys,
    I'm was about to buy this device, but as I see here in this topic many things is still not working as developer claim.
    I extremely hate when you have your device is listed in and your software or hardware fail to finish the job, or you
    can count you hart beats between pressing read button and displaying a result because your not 100% sure in your tool.
    And a specially making a experiments with costumer cars. I'm not against this programmer, I would like to this thing work well,
    looks interesting addition between rest of tools what we have. So I think that guys from X-Horse should remove things which
    not works properly from listings, just to have them there to make their product more attractive then others from the market,
    just to putt things which works so we will have more confidence in tool and developer.
    For example,
    I saw there is listed 28F400 flash, did any one tried this to read?
    Manual is to poor, no explanations about flash memories, for this programmer to read flash probably you need adapter, nothing about that.....
    Any one?
    This is one of the reasons why I'm looking on this tool, I know there is other ones which can do Flash...
    So my question is it worth spending app 500 euros on this device?
    Kind regards
  5. #320
    Apr 2015
    Quote Originally Posted by rob h View Post
    we have tested on XP WIN7 WIN8 WIN10 all work ok,next version we will make software as"software install package",like VVDI2 software update.
    then will install driver before run software.
  6. #321
    Apr 2015
    Quote Originally Posted by pundravac View Post
    Hi guys,
    For example,
    Any one?
    Kind regards
    thanks for your advise,new version User Manual will be finished within 2 weeks
    if you find bugs/not work well please post here/PM me.
  7. The Following User Says Thank You to Samic For This Useful Post:
    garagetech (15th February, 2016)
  8. #322
    Top Poster rust55's Avatar
    Apr 2012
    Nissancal
    Nissan 2013- calculator does not work
    Nissancalculatordoes not workafter 2013culatordoes not workafter 2013
  9. The Following User Says Thank You to rust55 For This Useful Post:
  10. #323
    Apr 2015
    Quote Originally Posted by rust55 View Post
    13
    friend,please tell me this issue in detail,i will check and help you.
  11. #324
    Apr 2012
    I wanted to add the smart key on the X trail 2014. Did the SKP-900 as a smart key2. The programming comes, but the key is not to prescribe but with NSPC001 skp900 Nissan makes no problems
  12. #325
    rob h's Avatar
    May 2011
    http://www.digital-kaos.co.uk/forums...ulator-mystery!
    Quote Originally Posted by Samic View Post
  13. #326
    Oct 2015
    Samic
    is it possible to add Nec
    MCU: uPD70F3624
    it for door blocks Volvo 2012-
    I think many
    you will be grateful
  14. The Following User Says Thank You to gigitalfvdi For This Useful Post:
    lidons (15th February, 2016)
  15. #327
    Oct 2015
    Soviet Union - USSR
    Hello Every One.
    About unlock NXP pcf.
    have some list where I can see car brand chip to unlock?
    I try unlock some, but result is zerro
    Anyone ever got sucsesfully to unlock anything, except for BMW E series
    here is my attempt https://mega.nz/#F!kc03DBoJ!8YopJwdI6A9L-OjquSM7kg
  16. #328
    Apr 2015
    friend,have checked about VVDI PROG Nissan calculator the algorithm absolutely ok.
  17. #329
    Apr 2015
    Samic
    MCU: uPD70F3624
    I think many
    mate,thanks for good advise.i wanna know this chip whether encrypted or not.
    if its unencrypted chip,i think we will add it in a short time.
    encrypted type maybe need more time.
  18. #330
    Apr 2015
    Quote Originally Posted by exSPEEDyTOR View Post
    Hello Every One.
    NXP pcf series unlock means chips unlock,it has nothing to do with remote.
    currently we provide the bmw E series program.
