Page 97 of 295 FirstFirst ... 47879293949596979899100101102107147197 ... LastLast
Results 1,441 to 1,455 of 4423
Thread: VVDI PROG
  1. #1441
    Sep 2009
    Hello everyone
    VVDI Prog reads and writes AMD 29F400?
    thank you
  2. #1442
    May 2017
    Quote Originally Posted by niwat_spp View Post
    Hi friends sorry I write wrong chip No.
    vvdi prog support R5F21548G?
    thank in advanced
    Yes,support.In the 2-MCU,RENESAS-R8C
  3. #1443
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    Hi guys.. anyone well-grounded that can help me with this confusion please ?
    I got some money to spent and is thinking to expand my services to BMW (EWS & CAS 1/2/3 - may be not for the latest CAS yet).. and is looking for a programmer. I already have Tango for starter.. do you guys think Tango + VVDI Prog is a wise choice and enough for the job i'm planning to cover (spare key adding and all key lost)? I was told that for EWS 1/2 i may need AK90 as well because VVDI Prog can't read it?
    I have read the thread from first page to the end, but since i'm not a practitioner yet in this auto brand, thus my knowledge is not as good as you guys, i'm afraid i may end up buying the wrong device. So, some advices from you guys will be helpful and much appreciated.
    Should i go for VVDI Prog or Orange basic (without Immo HPX) ? Or may be there is another option you guys can suggest me?
    Thanks for any helps.. best regards.
    PS : My apology if this question is not suppose to be here.
  4. #1444
    Aug 2015
    Indonesia
    - double post
  5. #1445
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by ucokseparoh View Post
    somebody who use VW never recommend BMW
    hope you find people who use both
  6. #1446
    doctore's Avatar
    Nov 2015
    Colorado Denver
    my mistake
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  7. #1447
    May 2017
    Quote Originally Posted by cavignac View Post
    Hello everyone
    thank you
    can't read and write temperorily,will add it.
  8. #1448
    Jun 2010
    Quote Originally Posted by lidons View Post
    @bero
    Try it several times!
    When problems occur, disconnect the PCf from + 3v for a while, Pcf without power
    Vvdiprog works at 3.5v put to 3.6v.
    If it still does not read, it has corrupted the PCF lock code and can not restore. Because vvdiprog does not recognize it. This possibility is scarce but existent.
    All this recognizing that you have done the normal manual procedure.
    sorry for the late answer, i was a week away.
    I tried also diverent volts if you mean the +3v from the cable (red one) i tried that also..
    Lucky, the PCF is not dammaged, and operates normaly
    There was also someone asking of snapshot pictures, but since i updated the software, the logs are gone, and don't have the remote here anymore
  9. #1449
    Nov 2012
    I made pcf reseting with vvdi prog on allot of remotes. It does erase, no problem. It writes no problem.
    Thumb's up for the tool. Working good.
    Only that you need a good dump for the pcf.
  10. The Following 3 Users Say Thank You to dorofteius For This Useful Post:
    lidons (5th September, 2017), sniegavirs (6th September, 2017), taxo1965 (10th February, 2018)
  11. #1450
    Basti13's Avatar
    UK
    Hello everyone
    VVDI Prog can read and writes tricore tc-1797 ?
    thx for info .
    NO PASS
  12. The Following User Says Thank You to Basti13 For This Useful Post:
    smokinjoe (21st August, 2020)
  13. #1451
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by Basti13 View Post
    Hello everyone
    thx for info .
    No. And those Tricores it can read is only some VW ecu's because VVDI Prog don't have security bypass for other... For example: Audi A3 ECU with tricore TC-1762 it cannot read!
  14. #1452
    sv2hqx's Avatar
    Jun 2014
    hi
    possible to add 9s12q128 0m66g ?
    thank you
  15. #1453
    recodes's Avatar
    Dec 2009
    UK
    Read MC9s12xdg128 2M42E tonight. Very smooth easy read and verify flash and eeprom. Security bit is at 1ff0f and is 0xfe unsecured.
    I erased the eeprom then erased the flash thinking of course the software would not be written so as to secure the chip and will write security byte 0xfe....
    No chip is now locked!!! Why do this?
    How do I recover the chip now please?
    Thank you
  16. #1454
    May 2013
    I have successfully read VW Beetle cluster with HC912.....
    Can I upload picture of the Cluster board and pinouts so that X-Horse can add it with diagram photo in the software?
  17. #1455
    Moderator
    PremierD's Avatar
    Jun 2009
    Of course you can mate ....
